C6/Z06 Staggered 18" and 19"
Fronts are 18 X 9 1/2 X 53mm and the rears are 19 X 11 X 73mm. If anyone is running this combo, please tell me what size tires you are running, and what I will have to do to make them fit on a 4th gen SS ?
i dont have the exact setup. but im running 19x10 all around with a 65mm offset. im using a 1/4 in spacer all around. 295/30/19 front 305/30/19 rear. but since u are running a 73mm offset rim. my guess is u might need a 1 inch spacer, or 1/2 inch with extended studs in rear. fronts should bolt up no problem
I just bolted on the front of my 18/19 combo i used a spacer on the front to give a lil more room but am told i really didnt need to. i ordered a 1.25 spacer that should be in tomorrow and ill see how much space i have.. Mines a stock suspension SS but my koni/bmr combo should also be in ant day now.. so within the next week ill know exactly how thing will stack up and ill post up something. wheels are exactly c6 but they are ccw with corvette offset.
Actually not sure how thick the front spacer is ... i happen to have it in the garage and used them to see how they did.. and was thicker enough.. when I put the new shocks on i may try with out them and see what hapens. The fronts are 275/35r18 the back is is 305/30r19... Im looking at the front on the rim and i think a 285 on a 10inch rim maybe better.
Small status up date for you got the wheels and spacers on the car.. Front fit great no issues lock to lock... the back fit with no rubbing so far.. but i only pulled it out of the garage and back in.. so it hasnt had suspension articulation.. with no BFH work on the car there is a less than 1/4 inch space on the inside.. There is no doubt in my mind i need to roll my fenders. Pictures to come when my shocks and springs come in. May open a new post.
