FIKSE 9.5" to 11"
Fikse 17x11 wheels for fbody are +44mm offset. They use 8" inner barrel and 3" outer barrel.
So basically if you go to a 3" outer you should be fine and it will "stick out" as much and have as much lip as any 17x11 you order directly from them. If you want this just for appearance then getting 3" outers only is the way to go and live with your 17x10 wheels. If you need them to be 17x11, you'll also need two 8" inner barrels.
Fikse 17x9.5 wheels for fbody are +38mm offset. They use 7" inner barrel and 2.5" outer barrel.
107318 17 FM/10 F116A18-3018 (In Stock Centers)
200725 Outer rim 2.5 X 17 2
201770 Inner rim 7.0 X 17 2
200730 Outer rim 3.0 X 17 2
201780 Inner rim 8.0 X 17 2
300802 Finish TechniPolish clearcoated with mirror polished outer rims uncoated
Front: 9.5 X 17, +38mm Offset
Rear: 11.0 X 17, +44mm Offset
Not to ask a dumb question, but could you possibly be referencing the serial numbers instead of the part numbers?
Hmm, I'm not sure. When I ordered new 17x9.5/11 FM10 from Fikse, my invoice has same part numbers for the centers. This is copied directly from my invoice from 2011.
https://ls1tech.com/forums/attachmen...ires-fikse.jpg
But that's just what I think.
So if you have Profile series then go of those offsets in link. If FM series, then the specs I listed.
