WELD RTS-71 Black 17 inch front wheel and tire options??
Old 08-09-2015, 08:15 PM
metlic53's Avatar
Default WELD RTS-71 Black 17 inch front wheel and tire options??
I have some 15x10 WELd RTS Black S-71s for the rear with 275/50/15 ET streets. I am going to buy some 17 inch fronts to match. I have some brand new 275/40/17 street tires to mount but they require a 9 inch wheel. What 17 inch wheel and offset should i put on my car?? Should i put a skinny wheel/tire or wider wheel/tire on the front?? Your opinions please. I like to drive the car around on weekends etc but mostly a garage queen. I do not know what backspacing wheel to get for the fronts. The backs are 7.5 but did require some grinding of the calipers.
Thanks for thoughts and pics if you have any. Help me with my decision.
Old 08-10-2015, 08:44 PM
bottlefed01z28's Avatar
ive been doing a lot of research on the same subject and i found this while on weld's website
http://weldwheels.com/wp-content/upl...-May-20141.pdf
looks like a 17x9.5 or 17x10 with a 7.3 backspace with a medium pad
Old 08-10-2015, 10:30 PM
metlic53's Avatar
Thanks for link. I cannot make my mind up on 17x4.5 or 17x9.5. Not sure if the wider wheels would look as good as the skinny. I know it will handle better for sure. Cannot find any pics of a car with 17x9.5s on it.
Old 08-11-2015, 06:06 PM
Most People who do this setup usually go for the skinnies up front. I know I am. If your worried about stopping power, it is decreased but in my case I have not found it to be at all noticeable. It would be hard to find someone who does big wall tires like you have in the back and low profile tires up front. Mainly cause big wall tires don't handle very well.
Old 08-21-2015, 12:07 AM
Mikey 97Z M6's Avatar
You could always go with 17x6, 4.3 bs and medium pad. Its a good compromise and fits well. I love mine. I used a 215/50/17 tire but should have used a 205. The sidewall bulges a bit more than I prefer.
Old 08-22-2015, 01:41 PM
MMorgan9812's Avatar
Dang looks great Mikey!!!
Old 08-23-2015, 05:48 PM
Thanks man.
Old 08-31-2015, 12:59 AM
Cstone812's Avatar
The 17x4.5 black alumastar 2.0s will look best imo with the rts on the back. I've got an order in right now for some been 3 weeks already.
Quick Reply: WELD RTS-71 Black 17 inch front wheel and tire options??
