(Updated pics 9/9/16) *17/15 Weld rts* LOW PAD!-Stock brakes- 01 Firehawk
Everything came from summit racing. Mounted and balanced the tires free of charge as well.
Fitment looks real good so far, can't wait to see them on the NBM car!
Digging the avatar as well
He is referring to the center piece you are showing being set deeper into the barrel of the wheel. Since the pad height it lower, the center can be set deeper into the barrel without changing the offset relation of the mounting pad to the wheel lip
The picture that shows the low/medium/high pad difference isn't a very accurate determination on how much further the low pad sets the dish in. The hub thickness gets thicker and thicker the more you go up in pad height, thus making less room for "lip". The pictures I posted of what I ordered vs the all polished medium pad wheel for comparison purposes shows the difference pretty good. ALSO, notice how my lug nuts come out further, as where the medium pad wheel's lug nuts are fully recessed down into the hole. Basically, if you want to have more dish in the same backspace, go with low pad. I would LOVE to see what these wheels look like in low pad with the 3" narrowed rears that many guys are doing. It already looks deep & killer in medium pad, I could only imagine how deep with low pad. IMO, I think low pad is a must do if you have a stock length rear end if you want any kind of dish. The medium pad in a 7.5" backspace almost makes the face of the wheel look "flat" to me....
Yep, looks even better than I hoped for
This is a stock width rear correct? The dish on that wheel is sick. Can't wait to see what this will look like with a 4.5" BS and my narrowed rear
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Looks fantastic! Thanks for taking a chance and reporting your findings. Do you happen to have the weld wheel part numbers for those exact wheels and the size of the front tires? M&Hs correct?
Rears are 15x10.275 with 7.5" backspace , low pad. Hoosier 275 drag radials in and M&H 185 front drag radial tire. PM me I can find some part numbers
So this will fit a stock length rear end without grinding down the inside of the quarter panel ?! How low is the car? My goal with my ta is the same look just a little bit lower but I want to run a 15x8 not a 15x10. Also does anybody know how much wider a trans am quarter panel is compared to a Camaro ?
Thanks! That's the look I wanted
#33
looks great...I was wondering about the low pads also. I'm looking at running a 17/15 combo on my s10. I have ls1 calipers on the front of my truck and 96 impala ss rear brakes. I might need to rethink everything now. I was already planning low pads on the rear 15x10s, but planning high pads on the 17s for the front. Maybe I can get away with the lows or meds on my setup.
#38
I just tried to build this wheel (rear) on welds website, and I could not. They don't even have a 10.275 option. They have a 10.333 with a low pad but only with the 5x120 bolt pattern
#39
#40
Bumping this. I just received my wheels. That part number DOES NOT FIT stock unmodified brakes. I'm going to assume that someone ground down badfbodyz rear calipers before he took ownership of the car. There is absolutely no way these wheels fit stock unmodified calipers in a low pad setup.
