(Updated pics 9/9/16) *17/15 Weld rts* LOW PAD!-Stock brakes- 01 Firehawk
Old 06-15-2016, 07:16 PM
badfbodyz's Avatar
Default (Updated pics 9/9/16) *17/15 Weld rts* LOW PAD!-Stock brakes- 01 Firehawk
*PAGE 3 POST 43 FOR UPDATED PICS* 17x5 & 15x10 with 7.5" BS. The low pad definitely added some lip to the rears that wouldn't be there if I would've ordered the medium pad for my stock width rear. The fronts are also low pad, and have plenty of room to spare. Today I've updated with pics of these mounted on my NBM 01' Firehawk. The reason I opted for low pad is because I wanted the fronts to tuck a little more than the medium pad 17's would've allowed since there is more options on backspace in low pad, and to get more of a dish in the rear with the 15" low pads instead of medium. Another benefit is the low pad is supposed to be slightly less weight because of a less curved spoke. This is on a stock length 8.8 rear end, and factory ls1 brakes. No grinding required, but make sure if you have your rears balanced that the put the stick on weights toward the rear side of the dish, not on the wheel spoke end, this way they are behind the caliper. Otherwise the weights can interfere with the caliper. Easy, just inform the person balancing the wheel. (Ignore a couple things I'm doing in the next few days, like changing out the exhaust tips,& having new roof installed cause of factory bubbles)
Old 06-15-2016, 08:55 PM
Ctdtim01's Avatar
In for pictures installed on firebird...
Old 06-16-2016, 07:45 AM
Rise of the Phoenix's Avatar
Those are going to look good on the Firebird. I like the front wheel size of 17x5. A very good compromise between a dedicated drag wheel and a wheel setup you can drive on the streets.
Old 06-16-2016, 09:09 AM
Captain Slow's Avatar
Where is the extra lip?
Old 06-16-2016, 09:54 AM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
Fitment looks real good so far, can't wait to see them on the NBM car!
Digging the avatar as well
He is referring to the center piece you are showing being set deeper into the barrel of the wheel. Since the pad height it lower, the center can be set deeper into the barrel without changing the offset relation of the mounting pad to the wheel lip
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 06-16-2016, 10:27 AM
badfbodyz's Avatar
Thanks! I'm absolutely in love with this setup. Exactly what I was looking for. And just wanted to spread info the fbody guys that low pad is an option that will work.
Old 06-16-2016, 10:46 AM
badfbodyz's Avatar
BMR explained it very well, I just wanted my rear low pad 15's to have more lip than the medium pads could offer. And with the same backspace. Here is a pic of an rts wheel, same width, same back space, just in a medium pad. Notice mine have more lip
My 15's for comparison
And I wanted low pad in the front, because it allowed me to get a 2.9" backspace, which let me tuck the wheels under the fender more. In medium pad 17's, they dont offer a backspace that pulls them in as far. Plus the low pad is a flatter spoke, which I like IMO.
Old 06-16-2016, 02:44 PM
Ctdtim01's Avatar
Curious if they will clear un modified ls1 brakes. I'm diggin the setup. Love the low pad look.
Old 06-17-2016, 03:56 PM
badfbodyz's Avatar
Updated with pics on Firehawk in original post. (Ignore roof bubbles, exhaust tips, unpainted calipers. Will be replacing those things next week)
Old 06-17-2016, 09:01 PM
MMorgan9812's Avatar
Looks great! Thanks for taking the risk and getting them to work, Really helps us with stock length rears have more options!!!
Old 06-17-2016, 09:38 PM
BOLO's Avatar
It's still the same amount of lip. Because the spokes are flat as opposed to curving out on the medium pad wheel, it does give you the illusion of a much deeper lip.
Old 06-17-2016, 10:34 PM
badfbodyz's Avatar
Looks a lot different to me, here's a comparison with same width, same backspace. Medium pad vs low pad.
Here's a random internet pic. 9" with 6.5" BS (med. Pad) vs 10" with 6.5" BS (low pad). Looks like WAY more lip than just 1".
Old 06-18-2016, 12:04 AM
badfbodyz's Avatar
IMO, the risk was well worth the reward
Old 06-18-2016, 12:20 AM
SteenH's Avatar
On behalf of all future searchers and I, thank you for the pictures. I was searching and searching a few months ago for answers, and decided when the time came I was going to go with the lows for even more lip with my rear narrowed 4" overall. Looks great! Thanks again
Old 06-18-2016, 09:01 AM
badfbodyz's Avatar
^ that's why I posted thos, to inform people that low pad is always an option. I see everybody only gets medium pad because they are "fbody compatible"
Old 06-18-2016, 10:54 AM
badfbodyz's Avatar
My street wheels, 17x7 17x11 200s
Old 06-18-2016, 11:29 AM
silverWS.6's Avatar
That looks really good! Are your fenders rolled? It kinda looks like they aren't, I might be wrong though. I'd roll those asap before they tear up those nice tires.
Old 06-18-2016, 12:47 PM
badfbodyz's Avatar
Yes I rolled them when I first installed my 17x11's. Thanks for looking out though! I couldn't afford more tires any time soon!
Old 06-18-2016, 06:20 PM
BOLO's Avatar
You're right, it looks to have more lip. And it does look a lot better than the medium pad wheel.
Old 06-18-2016, 06:33 PM
Ctdtim01's Avatar
Where did you get them if you don't mind me asking?
Quick Reply: (Updated pics 9/9/16) *17/15 Weld rts* LOW PAD!-Stock brakes- 01 Firehawk
