Proper Thread Engagement for Wheel Nuts
General consensus is engagement must equal the thread diameter so M12x1.5 needs 12mm of engagement, M14x1.25 needs 14mm of engagement and so on. So if 1 turn of the nut equals 1.5mm, then for our M12x1.5 studs we need a minimum of 8 turns. Only place I found this rule in writing was on McGard's site:
http://www.mcgard.com/index.php/cust...llationremoval
This rule only applies to steel stud/steel nut applications. For steel stud/aluminum nut applications the rule is 1.5 times the stud diameter. This means you would need 12 turns if using aluminum nuts on F-Bodies. Conversely, TireRack's website shows a minimum of 6.5 turns for M12x1.5 studs which counters the general rule of thumb and makes no mention of type of nut.
So what are the rules? Anyone hear any different ones or have a source for proper thread engagement?
I just swapped out my front studs to ARP 100-7708's because on stock studs with OEWheels DD C5's, I was only getting 5 turns.
Might want to check yours if you are running OEWheels. General consensus is engagement must equal the thread diameter so M12x1.5 needs 12mm of engagement, M14x1.25 needs 14mm of engagement and so on. So if 1 turn of the nut equals 1.5mm, then for our M12x1.5 studs we need a minimum of 8 turns. Only place I found this rule in writing was on McGard's site:
Might want to check yours if you are running OEWheels.So in other words, with 2.5" studs and 15mm spacer up front I get 23mm of thread engagement.
