Zr1 Or Weld???
Old Feb 4, 2005 | 04:44 PM
DopdBrd's Avatar
Default Zr1 Or Weld???
IM LOOKING AT GETTING 4 NEW RIMS FOR BASICALLY DRAG RACING. RIGHT NOW I HAVE AMERICAN RACING REBELS ON THE CAR AND LOVE THE WAY THEY LOOK. BUT I DONT WANT TO SPEND THAT MUCH CASH TO GET 2 18X10 WITH DRAG RADIALS. WOULD I BE BETTER OFF GETTING A SET OF BLACK ZR1's 17x9 and 17x11?? or should i just get some weld prostars??? also i have heard that you have to do lots of modifying with the weld rims?? what all do i have to do? i dont want to be doing alot to my car and if the zr1's are easier to install then ill just go with those. thanks
Old Feb 4, 2005 | 06:38 PM
NumberOneSled's Avatar
Get the Welds, they are much lighter and all you have to do to get them to fit is grind the calipers a little.
Old Feb 4, 2005 | 08:31 PM
WAHUSKER's Avatar
Apples & oranges here. ZR1 wheels are heavy stock style rims for normal everyday drving. Weld ProStars are lightweight rims intended for drag racing only. Grinding the front caliper to make Welds fit is kinda normal, where as ZR1s fit like the stock rims.
Old Feb 4, 2005 | 10:26 PM
2000WhiteTA's Avatar
I would get the welds. They are much lighter than the ZR1'S. You will have to do a little grinding but it will be worth it.
Old Feb 5, 2005 | 09:02 AM
DopdBrd's Avatar
what size tire and wheel should i run with the welds??? the back ones that is.
Old Feb 5, 2005 | 09:03 AM
DopdBrd's Avatar
how much modifying is needed??? i plan on painting my calipers anyways so if i have to grind them i can easily hide it. thanks everyone.
Old Feb 5, 2005 | 09:58 AM
chrismcdaniel's Avatar
id get the 15x10's with 7.5 bs...
here is a write up that will help with the grinding, i used it and it was spot on.
http://www.freewebs.com/casper9t9/dragwheelinfo.htm
Old Feb 5, 2005 | 10:04 AM
DopdBrd's Avatar
How much did your guy's Weld Prostars with tires run you??? I want to keep it under a grand hopefully. I can get all 4 ZR1's withtires for about 900.
Old Feb 5, 2005 | 10:16 AM
depends on what kind of tires you go with, but you can useally find a set on here used for 750 bucks.. But new, i think runs around 1200 with E.T streets and front runners... i could be off a little though.
Old Feb 5, 2005 | 11:49 AM
DopdBrd's Avatar
well i can get some cheap front runners for like 25 bucks a piece, two of my friends run them on their cars and they work just fine. the rears will be bfg drag radials. what is the difference between the prostars and the prostar xp??? and what size of rim and tire should i put in the back??? thanks for all your help everyone.
Old Feb 5, 2005 | 12:33 PM
For the back are you going to get the 15x8 or 15x10? You should probably stick with the 15x8 and a 275/50/15 Nitto DR. Also, go with the 5.5in back spacing with the 15x8's.
Old Feb 5, 2005 | 12:41 PM
DopdBrd's Avatar
if i can i think it would look cool to get a 15x10 with a 325/50/15 but i dont know if it will fit. how tall can i go on the tire size???
i like the nitto dr for the street but as far as the strip goes, i will get either bfg or mickey.
Old Feb 5, 2005 | 01:12 PM
JackZ28's Avatar
Welds, no question!
Old Feb 5, 2005 | 03:01 PM
Do you have a stock rear? Thats a lot of tire for a stock rear.
Old Feb 5, 2005 | 03:03 PM
DopdBrd's Avatar
ya its the stock rear. prolly next fall im goign to start a buildup and put a 12 bolt in it with a 383 lt4. but i figured i would get the wheels and tires now. if that is too big then what size should i go with???
