Front and Rear difference????
Old Jan 2, 2006 | 02:45 PM
02TrueBlu's Avatar
Question Front and Rear difference????
Im thinking about going 315/35/17's rear and upfront 275/35/17's. i keep reading about people going 275/40/17 up front and was just wondering what the reasoning was behind that.... isnt that the sidewall size???? ive searched for a good while now and cant get a solid answer out of it.
(ordering TTII's 17X9.5 and 17X11)
also spacing recommendations would be appreciated and how it worked out for you
Old Jan 2, 2006 | 02:56 PM
02TrueBlu's Avatar
anyone?
Old Jan 2, 2006 | 03:32 PM
Zymosis's Avatar
Wait more than 10 mins to bump, its still on the front page.
Second, go w/ 275/40-17 because then the front and rear tires will have the same overall diameter (within .1%)
Old Jan 2, 2006 | 03:44 PM
2K2WS6TA's Avatar
That's important if you don't want the ABS light staring you in the face
Old Jan 2, 2006 | 03:55 PM
TXAgZ28's Avatar
A) I don't think anyone makes a 275/35r17.
B) 275/40R17 was factory size on the SS/WS6. It works fine.
C) What the 2 guys above said about overall height matching and ABS lights
D) Anything but a 275/40 is Un-American (ok, I made that up...)
Old Jan 2, 2006 | 06:12 PM
02TrueBlu's Avatar
Question
so its ok to go with rear ???/35/?? and front ???/40/?? ?
what about 40 rear and 40 front?
Old Jan 2, 2006 | 06:26 PM
TXAgZ28's Avatar
The sidewall height is a percentage.
315 * .35 = 110.25mm / 25.4 (convert mm to inches) = 4.34 inches (sidewall height) * 2 = 8.68" + 17" (wheel diameter) = 25.68 inches (overall tire height)
275 * .40 = 110mm / 25.4 (convert mm to inches) = 4.33 inches (sidewall height) * 2 = 8.66" + 17" (wheel diameter) = 25.66 inches (overall tire height)
So you get two tires with the same overall diameter and you are OK.
Old Jan 2, 2006 | 07:32 PM
Zymosis's Avatar
its the 'aspect ratio' of the sectional width, therefore it would still have the same overall diameter.
proof from a sponsor:
http://www.discounttiredirect.com/di...foTireMath.jsp
