ASR OFF, ABS INOP, BRAKE lights on!
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
I have Kuhmo 165/80/15's on the front(max pressure 35lbs, I have 34 lbs)...and M/T DR's 275/60/15's(running 25 lbs) on the back
I can start the car and drive for a few minutes and then the ASR OFF, ABS INOP, BRAKE lights come on...
Is there anyway to fix this?
Thanks guys!
Thanks guys!
Originally Posted by LANDONZ
same thing has happened to me, I had to take the front hubs off to replace my studs for my lugs, ever since then my ABS INOP and ASR lights have been on ??
Originally Posted by 2K2WS6TA
It's the tire circumference difference that's causing your problem SgtB, the only way to fix it is to get the tire circumference difference to within 10%, so it's either bigger fronts or smaller rears
The best solution for your application is delete your ABS. Since your ABS is not working properly, it is useles in the state it sits in. It would be best to remove it OR change your setup.
We've got a complete ABS delete setup that completely removes the ABS modulator and brackets...this will clean up quite a bit of room and remove ~15 lbs from your engine bay...more if you have TCS.
I see these ABS problems quite often. More then not, ABS/TCS is more problematic for drag racing and road racing applications. Removing it will not change the feel of your everday use braking abilities. Actually, with our proportioning valves that are included in our kits, you'll be able to better fine tune front/rear brake bias issues with different combination tires, rotors, calipers.
Our base kits are 139.99. Kits are always in stock ready to ship w/in 24 business hours.
Steve
Steve
Steve
Steve
Originally Posted by SgtB
Thanks Steve I will Keep that in mind and probably get that in teh near future.
Many are hesitant to removing ABS/TCS but once they do, they wonder why they never did it in the past. Especially when they see a nice opened up engine bay without the added clutter.
Many are afraid thinking their everyday braking feel or control feels will be terrible or change...the contrary, it doesn't change. TCS is nothing but a pain to continually disable when you get in the car (or purchase a component to default it "off" when starting).
Trying to work around those "features" spending quite a bit of extra money for ABS troubleshooting or ABS added on the rear doesn't make sense for drag or road race applications. A rear end alone... not choosing ABS saves up to 200.00 in the end!
As I've stated before...Don't get me wrong, ABS and TCS is fine for an everyday grocery getter...doesn't make sense for a performance car.
Good luck!!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
You're welcome. Let me know if you have any other question or concerns.
Good luck!!![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Good luck!!
Originally Posted by CamaroSS621
i was told my ABS is on because I need a new module. Do you guys have any?
Easiest and best option in my opinion is to remove it. The only time ABS is even used is if you brake hard locking your brakes...if you've never felt pulsing in your brakes, you've never used ABS. When you've felt pulsing in your brakes, that is when ABS is active...no other times is ABS used.
Hope it works out in the end for you
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
Steve
Originally Posted by thirsty Z
disconect the battery same lights came on my z aint came back on since
Originally Posted by onebadLT-1
ok my car is 94 and a v6 but danm light have been on for about 2 years and i have stock wheels WTF
If you don't care about the weight and space, just remove the bulb in the dash or alter the lamp wire feed to it. If you do care and want it back on, you'll need to have the EBCM scanned for codes, then have whatever damaged repaired. If it is a rear sensor, then its not too expensive. If its the front sensors or EBCM itself plan on spending quite a bit to have it corrected...(probably over 400.00 when all is said and done).
...with your ABS turned off in your current position, the main thing that may be bothering you is your ABS lamp since you've been driving it without ABS for two years. Personally, I would not even bother correcting your ABS to function as normal, the choice is yours.
Would most state's inspections fail you for an ABS INOP light?? I know that here in Joyzee the fascists can (do?) fail you for any dash lights always on.
