275x40x17, what does this mean?
Old Apr 23, 2006 | 11:11 PM
jjyiz28's Avatar
Default 275x40x17, what does this mean?
i know the 275 is the width in MM i think of the tire. 17 is the inch in diameter, but what is the 40??
Old Apr 23, 2006 | 11:22 PM
98SuperSport's Avatar
your sidewall
Old Apr 23, 2006 | 11:39 PM
BackinBlack02SS's Avatar
275 is the width of the tire in mm
40 is called the aspect ratio. It is the percentage of the width in sidewall height.
17 is the diameter of the wheel
Old Apr 24, 2006 | 12:18 AM
Ell Ess Won's Avatar
Think of Runflats as being like 10.
Old Apr 24, 2006 | 12:28 AM
huh
Old Apr 24, 2006 | 12:29 AM
Originally Posted by BackinBlack02SS
huh
Nothing, just trying to make things easy...smaller sidewall = lower profile.
Old Apr 24, 2006 | 11:37 AM
Hugger Z's Avatar
BackinBlack02SS is right. 40 is the aspect ratio. It means your sidewall is 40% as tall as your tire is wide. So if you have a 275mm wide tire, your sidewall=275*0.4=110mm. And don't forget your wheel diameter is in inches so when you determine your rolling diameter you need to convert everything to mm or inches.
Old Apr 24, 2006 | 12:07 PM
If you're changing your wheels, this is a helpful tool in determining what sidewall diameter you want to look at so you won't have to change your speedometer reading.
http://www.discountpartcenter.com/tirecalc.html
