over size wheels messing with speedometer help!
Our cars came stock with P245/55/16's right? So if you put P275/20/20's on when your speedo says 71 you would only actually be doing 65 right? If so your speedo may have been changed by someone else before you got your car cause your numbers don't seem to compute. Or maybe I'm just not thinking correctly which is always possible.
EDIT: After checking the tire Calc. I'm wrong sorry. I had it backwards.
http://www.discounttiredirect.com/di...foTireMath.jsp
The stickies are there for a reason . . .
The Hypertech will adjust for over sized tires and gear changes . . . that is about all it is good for
