removing baked on funk on inside of rims ?
I have some yellowish funk on the inside of my expensive rims the only thing I think it could be is wheel wieght glue.
? can I use an abrasive cleaner like comet to clean this funk off?
Thanks
Thanks
If it indeed is glue/sticky stuff from a wheel weight then try "goof off" or "goo gone." Don't let the stuff sit on the rim too long as it may damage the wheel surface. Try to use either product with a rag to help remove the sticky stuff.
I don't think I'd try Comet on a wheel, especially a nice one. The Comet will scratch the surface pretty quickly. I'd stay with the over the counter wheel cleaners (I like Meguiars A2Z). It may take some time and elbow grease, but you won't damage the rim surface.
rims
I tested a small section on the inside back part of rim / a dishwashing soap the rough side & it rubbed off the clear coat.
next I'll try small part / peanut butter then goof off.
I've tryed armor all a few years back and it stripped small spots of clear off never again.
Thanks
Thanks
a2z
Thanks
Originally Posted by badmfkr
I've been looking around for this cleaner you suggest at discount auto & wallmart where is this a2z cleaner available?
Thanks
Thanks
Hot Wheels is Meguiars. The Eagle One is now in a silver bottle and called All Wheel and tire cleaner. It USED to be called A to Z wheel cleaner and in an orange bottle. If you have crud that is stuck on good you can use the wheel cleaner and a fine steel wool to get it off. I've used this on the polished cast exhaust tip on my truck to get off the baked on tar and gunk that has gotten stuck to it. It actually helps polish it. Then I go over it with some "Never Dull" to polish it.
finally got so time to clean
Goof off did'nt get the baked on funk off.
The only product I could find that was clear coat safe was the eagle 1 never dull it claims to be a cleaner and polisher however at there web site they say to clean the rim first then apply never dull?
never dull did clean the majority of the funk but not all.
is there any other cleaning product thats clear coat safe?
http://www.meguiars.com/?wheel-care/...-Wheel-Cleaner
Thanks
