18's
Old Dec 8, 2006 | 03:04 PM
mike02ss's Avatar
Default 18's
Will putting a 18 x 9 using 265/40/18's with stock offset of 56mm on the front of a stock suspension 02ss have any fitting issues? Thanks...
Old Dec 8, 2006 | 03:07 PM
Xsta Z 28's Avatar
Better to run a 275/35ZR18 tire . . . and that will fit fine.
Old Dec 8, 2006 | 03:08 PM
StillUnnamed's Avatar
Dude, i'm looking for a similar question to be answered. These guys should make a sticky that has every combination that works...that way we won't have to ask a million questions...don't you agree?
Old Dec 8, 2006 | 03:27 PM
mike02ss's Avatar
I want to run 265/40/18 bfg drag radials on the back and want to keep the same diameter all the way around thats why I asked if it would fit on the front without a problem. I have a hookup on ruff rims for 400 bucks on any set but they only come in 9 or 9.5 the widest. Still looking for an answer. Thanks... I want to kind of fill in some of the wheel well without lowering the car.
Old Dec 8, 2006 | 03:43 PM
FH212's Avatar
You should run a 275/35/18 on all four and they will fit just fine no rubbing and no problems whatsoever.
Old Dec 8, 2006 | 05:01 PM
Xsta Z 28's Avatar
UHHHHMm m mm m . . . .there is! . . .
Old Dec 8, 2006 | 05:11 PM
Brian2006's Avatar
and 275 is too wide for a 9" rim in my opinion. 275 is only recommended for a 9.5" wheel. Go with your 265 or maybe even a 255.
Old Dec 8, 2006 | 06:21 PM
Xsta Z 28's Avatar
Uhm . . . Stock wheel on a SS and Firebird is 9" and comes with 275's . . .
Old Jan 5, 2007 | 01:43 PM
Honboy1's Avatar
Can you get me a set for $500.00 and keep the extra $100.00. I just won some on ebay for $610.00.
