2.5" Wheel stud + 15x10 Prostars = NHRA legal?
Will a 12mm x 1.5 wheel stud that is 2.5" long protrude past the washer and into the hex at least 12mm on 15 x 10 prostar?
I will not be running a spacer!
Thoughts?
Thoughts?
It's iffy. I think the rule is the stud has to engage the lug head half the width of the head (from what a tech told me). If I remember right mine just barley pass through the center of the wheel. If you have a tech pull a lug and they see it poking through the center of the wheel they will probrably let you slide. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
FWIW: Weld lugs come with a thick *** washer, Mcgaurds come with a thin washer. Weld lugs also rust like crazy.
Originally Posted by SiL3NtXWS6
Stock length is 2.5inch. It will be iffy man.. very close.
