jegs skinnies on sportline car, what size tire?
hey all, im looking to put some skinnies on the front of my 01 SS. the car is lowered with eibach sportlines. was checking out the look-a-like prostars from jegs 15x3.5 . anyone have skinnies on a lowered car? what size tires do i need to get? any help would be greatly appreciated
i have the eibach lowering springs and i just put my skinnies on a few weeks ago. get the 15x4 jegs pro stars with 4.75 circle pattern and 1.75 back spacing. the 4.5 is 4 the mustangs. i ran no spacer up in the front but needed 2 grind the calipers down. id advice not putting spacers on. u might not have 2 grind the calipers most ppl they bolt rite up for them. all depends on ur brakes. 4 ur tire go with the 165R 80 15 kumho tire there like 32 bucks off tire rack.
good luck
good luck
im looking at gettin a set of MT sportsmans 8ply. is this gonna cause any problems since there bias ply and im runnin a nitto on the rear? also ive seen posts that the kuhmos arent meant for high speed and arent meant to handle the weight of our cars. my car is a weekend warrior with maybe 3-5 trips to the drag strip a year
there a tough tire tho. guys use them even into the 9s. u can get the MT sportmans 8ply id just go with the kumho's. good tire and cheap. i keep my skinnies on and drive around on the street with them everywhere and many of my buddies do.
good luck
good luck
The summit drag wheels are the same right? I tried bolting my summit front runner and and im going to need to grind just a tad off but not much. Im pissed because I spent alot of time getting my calipers really nice.
The jegs clear stock brakes...but depending on your pad/rotor combo even the jegs wheels may require a tad bit of grinding. With stock rotors and a little less than half material left on the pads they clear fine. However when I do rotors on the car and new front pads I may have to shave the caliper some. I'm going to keep the brush on caliper paint for this reason
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
