View Poll Results: What will look nicer and handle better?
Multiple Choice Poll. Voters: 38. You may not vote on this poll
Help!! 18" or 17'' chrome TT's 2
hi, I have a 2001 SOM camaro SS. I plan on buying rims A.S.A.P. I dont know if I should go w/ 17'' or the 18''. I plan on going 275 on the front and 315 in the back. I am also going to lower the car a bit. do I have to run low profile tire in the rear? or normal tires will be fine
Originally Posted by nicholas haycock
Just wondering what rim offsets you used
The sidewall difference between the 17 & 18 can't way different so they would simply just add more weight. I didn't buy these wheels to go to the track and run and since its not a full race car...I can let a little performance go for some damn good looks.
18's make the car look like it could go offroading. 17's in my opinion. That way you can get the 11" rim for the rear and the 9.5" for the front. And yes,,, tire selection is much better.
Originally Posted by stockerws6
BlackbirdWs6, are those Mecham 7.5" tips? They look nice! I also like the stance, what kind of drop is that?
They are the 7.5" ovals from Mecham. I would not recommend getting them because the chrome plating is hit or miss. I had a set before these that bubbled and the chrome flaked off. These are the replacements from Mecham and so far so good. If they do have the same issue, I'm going with something else. I actually have no drop on the car lol (lovely stock sag from age). The rear is a bit lower because I have maybe 50+lbs of stereo equip. in the trunk.
-Brian
