Pics of a "40 wide" on a 9.5'' wheel?
Restricted User
It also depends on the design of the tires. Nitto's run narrow, so they will probably look odd in that size. However a tire that runs wide will probably look normal. It also depends on your taste. I absolutely despise tires that are too narrow for the wheels they are on. It looks ricer-retarded to me. I always try to go as wide as safely possible.
The 255/40/18 will lean in. A 275/35/18 front and 295/35/18 combo would work well, assuming you are doing 18x9.5 on all four corners. Been doing ALOT of research lately on tires and rim combos. I have 255/35/18s mounted on a 9.5 on the front of my TA and they look terrible. But I am going to an 18x8.5 wheel so that tire will work well on that wheel. In the rear I am looking to go with a 295/30/19 on a 9.5 wheel.
Originally Posted by 1998Z28LOADED
A 255/40/18 because it the same overall diameter as the 295/35/18's Im puttin on the back....
Im just worried that the sidewalls will lean in...
40 is the side wall height. 255 is the width so a 255 on a 9.5 regardless of the side wall will not look good. a 255/50 or 255/60 255/30 none of these will be wide enuff. just differnt heights.
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Some guys came up and asked me what size tires i have in the back because they were huge. I said they are 315's. They just gave me a blank look, and asked "Oh, so is that a 40 or 50 series?" So i said "Well, its a 315/35/17..." Got the blank stare again. "They must be 50 series." What the **** is that supposed to mean? Is this old school terminology that I don't know about, or were these just stupid rednecks?
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Originally Posted by BigJls1
you should asked about a 255 on a 9.5 rim.
40 is the side wall height. 255 is the width so a 255 on a 9.5 regardless of the side wall will not look good. a 255/50 or 255/60 255/30 none of these will be wide enuff. just differnt heights.![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Originally Posted by Jakson
Some guys came up and asked me what size tires i have in the back because they were huge. I said they are 315's. They just gave me a blank look, and asked "Oh, so is that a 40 or 50 series?" So i said "Well, its a 315/35/17..." Got the blank stare again. "They must be 50 series." What the **** is that supposed to mean? Is this old school terminology that I don't know about, or were these just stupid rednecks? ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Restricted User
I just looked it up and found that a 255/40/18 is: 10.04 inches in section width, that wouldnt work on a 9.5 inch wheel?
A 275 width tire is 10.8 inches section width and that gives a perfectly flat sidewall. Going larger will cause the wall to taper out (gives a more aggressive look), going smaller will cause the wall to taper in (gives a really odd look).
You have to remember that a 9.5" wheel is 9.5 inches from beadseat to beadseat. The wheel is actually about 10.5" from outer rim to outer rim. You never want a tire that has less section width than the rim-rim width of the wheel it's on.
