will 275/40/17 work on a 11" wheel?
What? I put 275's on my 9.5 in rims. I put 295's on my 10.5 in rims. These are the perfect fits.
I don't see how you could reasonably fit a 9.5 inch tire on a 11 inch rim.
The original question was if you could mount a 275/40 on an 11" rim. (A), the Tire Rack manufacturer's charts say it's OK. (B) You divide 275 by 25.4 to get the tire section width in inches, and the answer is 10.8". Why wouldn a 10.8" wide tire not work well, or look good, on an 11" wheel??
![Thumbs down](https://ls1tech.com/forums/images/icons/icon13.gif)
If you want to talk looks, I think that there's nothing worse than a tire whose sidewalls are "pinched in" to fit on the rim. In other words, a tire that's mounted on the minimum width rim for that particular size of tire. BUT, that's srtictly my $0.02 worth.....
I think we all agree with that, BUT in this case the OP has 11in wheels, so the "pinched in" really doesnt apply. Like mentioned above. The whole reason for having 11in wheels is to throw some 315s on the back, not throw some 275s on, rather pointless IMO.
Tough Mudder
I wonder if there would be any benefit to running a 275 tire on an 11" wheel. Would the tread be spread out more?
changing the equation
If someone had a pair of 275 tires and was buying wheels for them, is there a benefit to putting them on 11" wheels rather than 9.5" wheels?
from what i saw above the only way anyone can see any advantage in them is if you were to road race or auto cross for cornering purposes so the tire will not roll on the wheel. Which is true from my years of circle track racing. If you were using them for drag/traction or look youd definetly not want to run them.
