38 mm offset looks?
Old Apr 14, 2008 | 11:35 AM
toslo5o's Avatar
Default 38 mm offset looks?
i went to order the rpm 505 19x9.5 in a 38mm offset and i was told they would sit too far in the fender making them look funny?? i was told this buy the supplier does anyone know if this is true?
another supplier tried to tell me i need a lower offset like from +20 to 0 to make them fit????
i'm confused, these wheels look just like the evo's....
Old Apr 14, 2008 | 11:46 AM
98redM6's Avatar
They don't know jack. You should be okay. +38 is one of the lower offsets recommended to run on a 9.5" wheel.
Old Apr 14, 2008 | 12:39 PM
caliswangin916's Avatar
i have the rpm 505 in 19's and i think the 38 offset looks good. it is roughly 1/2 inch away from the fender before you roll the fender on a stock rear. i like the tucked look. it's not aggressive though. i'm running a 9.5 with 38 offset and the rear is narrowed 1" so my wheel is really far in and looks good without having to worry about rubbing.
on your car, i'd roll the fender to be even safer. i have the vredestein 275/30/19's and don't recomend them right now. the 275 curves away from the rim and does not look good. and definitely do not combo that tire with a 245/35/19 front if you are on 19's due to tires looking bigger in the front. i recomend to go with a 275 or 285/35/19(backs) and 245/35/19(fronts).
biggest problem i had is the 275/30/19 vredesteins are not putting enough tread on the ground. it may be specifically with the vredesteins. that section width only puts down 7.5" onto the ground. i'm going to check my tire pressure but they should not be off of the recomended. just typing all of this to help others out too. hope you can use some of it.
Old Apr 14, 2008 | 01:51 PM
Xsta Z 28's Avatar
Front 38 mm offset 9.5" wide wheel:
Old Apr 14, 2008 | 08:54 PM
WS6Jim's Avatar
I have RPM 505 in 18x9 with a 38 offset and it looks good to me.
Old Apr 14, 2008 | 11:11 PM
jdoyle's Avatar
does this apply to zr1s as well..?
should i grab a 38mm offset 17x9.5 front and put a 50mm 17x11 out back? should i get the 38mm rear as well?
are you lowered? ....wheel shopping.....
Old Apr 15, 2008 | 01:24 AM
toslo5o's Avatar
hmmmmmmmmm, i was goin to get 275/30r19 vredestein's all around... i'm not too worried about the contact i already know i'll have no traction with 19's. i'll probably still go with them for budget issues
that's what the stock 16's are for
i really appreciate everyone's input and the pics were very helpful
Old Apr 15, 2008 | 07:56 AM
Xsta Z 28's Avatar
Sure, for the 9.5" wheel, 38 mm fits great front and rear.
11" stay safe and stick with the 50 mm.
Yes lowered ~ 1" all around.
Old Apr 15, 2008 | 02:33 PM
jdoyle's Avatar
xsta,
that 38mm 17x9.5 and 50mm 17x11 combo would not look weird would it? And when I say "weird" I mean like a FWD drag car with the slicks sticking out really far in the front and the skinnies in the back are tucked under.
Did you have to do anything to the front fenderwells? Is there any rubbing up there when turning? I'm assuming the answer is no since you said that they fit great, but I'm compelled to cover all bases.
Thanks for all the help!
Old Apr 15, 2008 | 03:37 PM
jdoyle's Avatar
the fronts should only stick out about one half of an inch further than the rears because of the 12mm difference in offset, correct?
Old Apr 15, 2008 | 04:51 PM
Xsta Z 28's Avatar
xsta,
What? . . . Do the front wheels and tires in the picture above look wierd???? Do the tires above look like they stick out of the wheel well??
The front fenderwells are plastic, the fenders are composite you can't do anything to them . . .
Do the wheels rub, well honestly yes, does it affect anything no. Again teh fender wells are plastic, so they flex when the tire contacts the wheel well liner at full lock. You do not feel or hear anything. . . . . Below is where and what the rub make looks like.
Read the "sticky" at the top of the page . . . all 40 some thing odd pages where I have possible answered this more times than I care to answer . . .
Old Apr 15, 2008 | 04:57 PM
Xsta Z 28's Avatar
Read the sticky to understand offsets. . . .
If you were comparing a 38 mm offset 9.5" wide wheel with a 50 mm offset 9.5" wheel, yes the 38 mm postive offset wheel will move outwards by about 1/2" compared to the 50 mm offset 9.5" wheel.
Comparing the "placement" of two difference sized wheels wth different offsets is very complicated, and you ahve to understand how "offset" relates to the wheel size.
There may be 12 mm difference in offset, but there is over 38 mm difference in over all width of the two wheels . . .
Old Apr 15, 2008 | 06:49 PM
jdoyle's Avatar
thanks for the help xsta, i need to get my sh** together! im definitely a wheel newb
