RED Camaro & T/A's with black rims. Anyone?
http://www.picturetrail.com/gallery/...mgid=255604462 there are some pictures of my car a few months ago...its changed a little bit but gives you a decent idea of what it looks like
ok like all the numbers listed.. hold on ill copy and paste it
* 4 - 17x9.5
* 2 - 17x9.5 and 2 - 18x10.5
* 2 - 17x8.5 and 2 - 17x9.5
* 2 - 17x8.5 and 2 - 18x9.5
* 2 - 18x9.5 and 2 - 18x10.5
ok like what do all these numbers mean?
and why are there so many diff choices?
and how do i know if they all will fit on my car or what size tires i should use for these rims?
* 4 - 17x9.5
* 4 - 17x9.5 - You will have 17x9.5 rims on all four corners, easy to rotate and tires are cheapers
* 2 - 17x9.5 and 2 - 18x10.5 - 17x9.5 in the front and 18x10.5 in the back. You wont be able to rotate tires and tires will be more expensive compared to getting 17x9.5
* 2 - 17x8.5 and 2 - 17x9.5 - 17x8.5 in the front and 17x9.5 in the rear. Wont be able to rotate, turing radius will be good up front
* 2 - 17x8.5 and 2 - 18x9.5 - 17x8.5 in the front and 18x9.5 in the rear, wont be able to rotate tires
* 2 - 18x9.5 and 2 - 18x10.5 - 18x9.5 up front and 18x10.5 in the back. Wont be able to rotate and tires are verey expensive. I just spent $600 on two tires for the rear
