Any one running 28 x10.50s on there Fbody?
I have a 98 Trans am, I put some 28 x 10.50 15 on my weld 15x10 wheel on the car I cant even fit a finger behind the tires at the plastic of the body. Anyone running these and if so what mods to do so.
Well if you'll talking about a 28x10.5x15 M/T ET Drags then yes you will need to do some pounding in the front inner fender well and remove and cut your bump stop mounts off clean, plus you'll rub a little on the back bumper which you can just cut off that little peice of triangle plastic there as well, I ran that and now i run a 28x11.5x15 ET Street, the differance is the section width and the tread width.
ET Drags-section width 11.70"..tread width 10.00"
ET Streets-Section width 11.10"...tread width 8.60"
Hope this helps....
Hope this helps....
Rear shot with the 28x10.5x15S M/T ET Drags.
Side View with the 28x10.5x15S M/T ET Drags.
Rear side view with the 28x11.5x15 M/T ET Streets.
As you can see there isn't much of a differance except for about a half an inch or so...and the fact you don't have to beat the crap out of your car as well.
