Will these speakers work ?(Infinity 602CS)
I really don't know too much about audio, I'm just looking for something that's basically plug and play and will work well with an otherwise stock Monsoon system.
I was at Best Buy today looking at speakers, and the Infinity 6020CS 6.5's sounded AWESOME. They come with tweeters and crossovers.
http://cgi.ebay.com/NEW-INFINITY-602...3A1%7C294%3A50
In my door panel there's a spot for the tweeter, so no problems there, but what do I do with the crossovers? Do I even need those?
And I know I need 2ohm speakers, but these are listed as 2.65 Ohm. Close enough?
I was origianlly thinking I wanted Infinity Reference 6022si's,
http://cgi.ebay.com/INFINITY-REFEREN...3A1%7C294%3A50
but the 6020cs sounded much better. Not that the 6022's sounded bad, just the 6020's sounded GREAT.
If I'm going to have a headache with crossovers, would I just be better off w/the 6022si's? I'm sure they're still 10x better than stock.
Or what about Infinity 62.7i? Anyone run those?
I mostly listen to rock and punk, btw.
Any suggestions would be much appreciated.
Thanks!
and since you have a bird any 6.5 component setup will do.
As for your setup, You WILL need the crossovers for a component setup, but keep in mind MOST aftermarket component setups are intended to be powered by aftermarket amplifiers. And, your factory components are already crossed-over at the factory amp, so sound quality WILL probably be compromised.
Also, I am willing to bet the speakers you heard in the store WERE powered by an external amplifier, and not the head unit. If keeping the monsoon setup, remember this....the factory speakers were meant to be powered by the factory amp. That being said the power is equally matched. Don't expect the same sound experience that you had in the store compared to your car. The biggest improvement you can make is the head unit, think of it has the brain of your sound system, the smarter the better right?
That way you ditch the monsoon, factory amp, and crummy factory speakers. Also you can switch to the typical 4ohm speaker setup.
In summary, yes you can switch to those speakers. I think there are better out there for the price. You will need the crossovers. The 2.65ohm WILL work. If you stay monsoon go with the reference series speakers, if you go externally amplified and a new HU get the next step up. Don't waste your money on something the monsoon cant power properly.
! If you don't want to deal with the X-over go with a good set of Co-axial or Tri-axial speakers.
And, Flaring Afro..... What's with all the Polk hype in the past couple threads, are you a rep? Those speakers are alright at best!
the polks are certainly better than infinities. there are better speakers out there, but i listened to most of whats in its price range and the memphis, mb quarts, etc werent as clear sounding. but like i told him he should go in and listen himself. i've never told anyone to def buy the polks, but when people ask what they suggest, thats it.
purely personal opinion.... I have heard very nice infinity reference series setups (polk also, but saying one is "certainly better" is not true).
One other thing we "certainly" agree on...
Also, did you need a spacer for the fronts? I know you said you didn't for the backs...
