CarPC How To [And worklog]
Old Apr 21, 2009 | 10:06 PM
  #61
Vicinity's Avatar
Originally Posted by cookba
ya i looked at the first post and didnt see anything. keep us updated on your build!
http://www.newegg.com/Product/Produc...82E16811234021
Ordering the monitor later tonight.
Old Apr 21, 2009 | 10:18 PM
  #62
Vicinity's Avatar
http://store.mo-co-so.com/index.php?...roducts_id=182
Settled on this monitor. It has a harness and is set up for CarPC use.
They also sell a nice cheap OBDII interfacing device.
Old Apr 22, 2009 | 02:36 AM
  #63
199TAmaster's Avatar
You werent lying about the cheapness of there OBDII connectors 35 bucks thats really cheap. I like the monitor to, takes away alot of trouble.. I mean pay 200 and deal with all the take apart and hassle or 250 for that. Good find
Old Apr 22, 2009 | 04:41 AM
  #64
Vicinity's Avatar
Yeah, that's what I said. Lol.
Hey guys, time for me to call for some help. I've never routed power wire in a car before so I'm not to sure of this.
I'm getting some 8 gauge to run the PC, screen, and amp. I'll have a 60 AMP fuse right after it comes off the battery and it will go into the cabin. I need to get it in the dash, under the pass seat and to my truck. How can I go about splitting it like that? Like, what are my options?
**So everyone is aware, the monitor posted earlier was just purchased by me along with a car power supply. But do not buy their GPS, its overpriced.**
Old Apr 22, 2009 | 12:12 PM
  #65
Flaring Afro's Avatar
btw a month or 2 ago i bought a slot load cd drive for $7ish dollars new off amazon. Doesn't read DVDs (or didnt list it) but better the ones that do are around $80. It has a mac jack but you can get a cheap any ide to usb adapter on amazon too. I think im going to make a slit at very top of bezel at crease and mount it there but not sure yet (let me know if you have any ideas). I'll just use the frontend to eject the disc instead of a button.
EDIT: like here, stealthy. but my screen will be 1.4" bigger.
Old Apr 22, 2009 | 02:16 PM
  #66
This is what I would use to direct the wires
http://cgi.ebay.com/ws/eBayISAPI.dll...%3D4%26ps%3D10
Old Apr 22, 2009 | 07:24 PM
  #67
transambandit's Avatar
crappy thing, my 8" just crapped out on me, so now i have been trying to put in my 10" and that thing is a monster, i cant figure out a good way to mount it in there, so right now i will be hooking my ipod directly to my amps to listen to anything. Im thinking about just selling this whole set up and getting a double din, its a PITA
Old Apr 22, 2009 | 08:52 PM
  #68
^ did you check this thread?
http://www.mp3car.com/vbulletin/gene...-firebird.html
someone had a 10" in it, or at least a concept photoshop. just take it by an audio shop and have them mount it. cant be more than $200, and thats way cheaper than double din.
Old Apr 24, 2009 | 12:29 AM
  #69
Vicinity's Avatar
Ok, I got my monitor... but I have a problem. It keeps displaying "No input signal" and I cannot for the life of me figure out whats the problem.
Someone please help!!
Old Apr 24, 2009 | 12:51 AM
  #70
SparkyJJO's Avatar
Tested it on another pc?
Old Apr 24, 2009 | 01:02 AM
  #71
Vicinity's Avatar
Yes. Several. Does the same thing.
Old Apr 24, 2009 | 01:13 AM
  #72
bad_408_vert's Avatar
with the pc your are putting togather, its kinda hard to troubleshoot because something like ram could be loose, video card not set up properly.
When you connect to a trusted computer that shows output on its regular monitor....are you connecting this monitor as the 2nd monitor because sometimes you need to change settings to display something on the 2nd monitor.
If you are connecting it as a primary moniter to a trusted computer and still shows same error, disconnect the cables from the lcd and connect them again. What kind of connectors does the lcd use to connect to pc?
Im assuming its regular db-25.
Old Apr 24, 2009 | 01:19 AM
  #73
Vicinity's Avatar
I tried running it to my main PC and my car PC. I have 3 other monitors and all of them work on both computers. The Touchscreen uses a 9 pin to VGA cord to connect to the PC.
Old Apr 24, 2009 | 01:24 AM
  #74
SparkyJJO's Avatar
makes me wonder if the screen is bad
Old Apr 24, 2009 | 01:54 AM
  #75
Vicinity's Avatar
I don't think the screen is bad, otherwise it wouldn't make connection. There's a plug on it, I'm thinking of cutting it open and splicing the wires.
Old Apr 24, 2009 | 01:58 AM
  #76
Vicinity's Avatar
I GOT IT TO WORK! ALMOST DONE! Pics in a few!!
Old Apr 24, 2009 | 02:03 AM
  #77
I was thinking that with the monitor you picked up and with the bracket it would probably be easy to mount the brackets for the stock radio to it, i think they just unscrew, if i cant get my 10" screen to work i was thinking about doing that. Maybe use some abs black plastic to fill in the gaps, would look pretty stock.
Old Apr 24, 2009 | 02:07 AM
  #78
Vicinity's Avatar
Old Apr 24, 2009 | 03:04 AM
  #79
Windows 7 dumdumdum...On another note you suck dude I am now prolly going to do a summer project on mine.
What software are you going to use for the OBDII?? I havent really found one I am a fan of
Old Apr 24, 2009 | 03:05 AM
  #80
What brand is the 10'' I am interested just pm me a price and some details.
