Installed Underdrive pulley setup how to get higher voltage?
Is there anyway to make the altenator charge more? I get about 11.5 volts out of the car and I want a constent 12.5 or higher is there any wiring tricks to make it put out more?
I am going to order this http://www.texas-speed.com/shop/item...id=37&catid=16 altenator pulley from texas speed unless someone knows of one that is slightly better I have not been able to look at summit or jegs yet going there now
You need the OVERdrive alt pulley...http://www.thunderracing.com/catalog...vid=3&pcid=111 I run the asp crank and over alt. pulley on my car. Along with a 160amp alt. I got my alt pully from Thunder and my crank pulley from Speed Inc.
