View Poll Results: Which speaker will best replace the stock sail panel speaker for the Firebird
SPR-17C Alpine - 6-1/2" 2-Way Coaxial Speakers (4 ohm)
0
0%
INFINITY kappa 62.9i 2-way car speakers (2 ohm)
1
16.67%
Polk Audio DB651 6.5-Inch Coaxial Speakers (4 ohm)
0
0%
Infinity Kappa 62.7I - Car speaker, 75 Watt 2-way (2 ohm)
0
0%
Infinity Reference 6022si 6.5-Inch Two-Way Shallow-Mount Loudspeaker (2 ohm)
0
0%
Another not listed here?
5
83.33%
Multiple Choice Poll. Voters: 6. You may not vote on this poll
Sail panel spk's gone-best replacement choice?
I need a good sail panel speaker replacement for the stock system in my '02 T/A.
I've searched thru the archives but most of the recomendations are to start from scratch and redo the whole shebang.
There were a few threads from awhile back talking about possible replacements but there wasn't a real clear concensus.
I've found a few that may work with the stock head unit, all of these are either 2 or 4 ohm (I'm still unsure which ohm spec is the correct one to get).
Please take a look and tell me if one of these is a good choice or if there is another one I'm not aware of.
Thanks,
Thanks,
I got some Elemental Designs 6.5" subs. Your sails are bass speakers, so the speakers you listed in your poll won't work. The sails only put out low frequencies. There's a sticky about how many ohms you should have. I'll try and find it
dual voice coil 6.5S (4-ohm + 4-ohm) subs mounted in the sail panels
Here's the sticky...https://ls1tech.com/forums/stereo-el...nsoon-faq.html
here's a link of the install I did. they sound good
https://ls1tech.com/forums/stereo-el...ed-eu700s.html
Went with 8" earthquake sound shallow mounts (sws series) in my sails.
Used an airsaw to enlarge the speaker cutouts to a 7 3\4 in hole. Can be bought in both 2 or 4ohm applications. They also have 6.5 inch versions. Used dynamat to reinforce the sails.
Used foam (in a can) to seal holes in cavity from behind sails. Great bass!!
Look at your factory speaker. My sails were stamped 2 ohm, which is what I needed if staying with Monsoon setup. I opted for 4 ohm, scrapped the Monsoon system. Sounds ALOT better. Made my monsoon setup sound like an AM radio.
Yes they are. The sail panel speakers in T/A's are two way speakers, not JUST bass speakers.
If you have full range sound coming from that location (sail panels) and have a Monsoon equipped car that is a coupe, (verts are different) then someone has wired your car up differently and it wasn't GM.
