Hardwiring radar detector
I have the wires all run, up the A pillar etc, looks very clean, mounting it up by the power mirror.
I was looking to tap the radio power wire near the inside fuse box but the back of that is a bitch to get to, so I can't exactly follow the wires from the back of the box. I also have my PAC swi tapped to the radio power so here's the questions.
1. Would it be too much to have the PAC and the radar detector both tapped to the single power wire?
2. Would I be better off tapping the cig lighter and putting a 2 way switch afterwards?
I'm a total electric noob but I like doin things myself, preferably the right way the first time)
aiming so it powers on and off as the car does
thx
There are three ports on the front of the fuse panel that were designed by GM for adding electrical accessories. They take quick disconnect plugs (flat, like half of a fuse) and are 15 amp circuits. They are labeled IGN, BATT, and ACCY. The IGN port provides ignition switched power. The BATT port provides constant (battery) power. The ACCY port provides RAP (Retained Accessory Power) power like your radio - it goes on with the ignition but stays on after the car is shut off until a door is opened.
You can crimp (or better yet, solder) a quick disconnect connector on the end of your FUSED power wire for your accessory. Remove the bolt holding the fuse panel so that you can feed the wire to the front of the fuse panel from behind the dash. Plug the wire into the appropriate port, bolt the fuse panel back and you're done.
Even though those ports are fused, you should always include an inline fuse of appropriate size for the accessory and the wire gauge you connect. For example, your radar detector probably has a small current draw (maybe 3 amps) so leaving it on a 15-amp circuit without protecting it with a smaller fuse could lead to problems.
Mine is wired into the mirror, "retained power"
circuit. I didn't take pictures. Shop manual sez
Blu/Wht is power and Blk is ground, up there
(pg 8-220).
