Question To Kee Audio about woofers
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
hey i was on the kee audio website looking at mid-bass speakers and small subs. my sail panel speakers in my 99 trans am monsoon system are blown out. i want the best sounding bass that i can get out of the small sail panel speakers. i looking around 120 dollars. are the Bazooka 6.5" Dual Voice Coil Subwoofers going to give me the best bass sound for my car? any advice would be helpful. thanks, kyle
I know that the CDT CL-E6NEO 6.5" midwoofers are better than Audipipes, but they are not dual voice coils. However They are compatible and sound pretty good with Monsoon & amp.
My personal experience. Lets Ian Kee answer your question with more technical data.
Regards
dochidalgo
I got the Audiopipes also and they rattled like crazy eventhough I got Secondskin lining the insides.Like doc said I used two sided foam tape between the speakers and the speaker metal and covered all the exposed holes.WOW,just doing that made a huge difference.
i bought the CDT neo sailpannel speakers from kee audio and they work pretty good.. good punchy bass, not overpowering
only complaint is they didnt directly bolt up to stock 4 holes.. bolted up to 2 of them fine and i made the 3rd hole work..
good enough for me
good enough for me
if you want more bass, the Tang Band W6-1139SI has the Xmax (cone travel) of a 10" subwoofer but is 6.5" and handles power very well; it only requires like 40-50 watts and is 4 ohm so it should work fine with whatever head unit or amp you have in there now. If you want good bass but with a lot of midrange clarity then the Dayton rs-180 4 ohm speaker is the best bang for the buck, period.
I just installed mine today drivers side is sounding great as is the passenger when not installed... its not so much a rattle but I can tell its either not tight enough (cant make it any tighter) or metal is shaking. So you put the tape around the entire whole hole where the speaker mounts?
There are a whole world of great performing possibilities that open up when you go aftermarket for the sail panels. The problem lies in that when you want to keep the stock amp it limits your choices down to a handful of companies if you want to keep optimal power output from the amp.
Going aftermarket opens you up to many viable, quality possibilities.
