Wiring info
Now the subwoofers are two 12 inch 600 watt rms each at 4 ohms. Now I am thoroughly confused as to what amplifier I will need if I am going to run it in parallel vs series. I can't get it straight how to calculate what I need. I know how to calculate the impedence compared to each other, in parallel it will be 2 and series it will be 8, so I need a 600 watt 8 ohm amp for series or a 600 watt 2 ohm x 2 channel for parallel?
For the subs, you could wire both subs to a single channel amp. Wiring them in series produces an 8-ohm load for that channel. Wiring them in parallel produces a 2-ohm load for the single amp channel. Or you could get a two channel amp and wire them each to their own channel (not the best way). Your best bet is to get a single channel, 2-ohm stable amp (most are) and wire your subs in parallel to that channel.
For your setup, you could wire the subs in parallel to an amp that produces 1200 watts into 2-ohms. You can also use a lower powered amp but you won't be using all the capabilities of the subs (a 600 watt amp could only produce half the power that the subs are capable of handling but if that's loud enough then it doesn't matter).
Note that there is no difference in output between using the two subs wired in parallel to a single channel amp producing 1200 watts at 2-ohms and the same two subs connected to two separate channels of a two channel amp producing 600 watts per channel into 4-ohms. Both cases produce 1200 watts of total power.
