GPS antenna and SWI-Jack ?
And on the SWI-Jack, I was wondering where should the power for it come from. I wasn't sure if I should tie into the power for the radio or somewhere else. Any help would be great. Thanks
I also put the SWI-Jack in there too, that way you have access to the stereo wires.
Instructions (in case you need them)
How do you get that pad up?
- Remove your t-tops.
- Remove the two screws at the top of the a-pillar trim on each side and pull off the trim. A gentle twisting motion will help release the clips holding it on.
- Gently pry up the upper dash pad. It is held in place by a combination of clips and squares of Velcro. Work carefully because the plastic tends to get brittle with age. Also use caution with the edges - they are very sharp (...he says as he types with only 9 fingers).
Replacement is the reverse of installation. There are a couple of locating pins on the dash pad that have to be lined up with the holes in the dash but once you have it lined up it just presses into place.
"gps antennae"??? You have more than one antenna?
Last question, I promsie
Removing the headliner takes a bit of work but isn't necessary for a GPS antenna. You can remove the a-pillar trim from one side, run the antenna wire up under it, and just tuck the antenna inside the leading edge of the headliner without pulling the whole thing down. A little Velcro or 2-sided tape will keep it from sliding around. This location doesn't give you any ground plane and takes almost as long to complete (you have to remove the a-pillar trim anyway and you also have to remove the passenger side knee panel and kick panel to route the antenna wire from the HU to the a-pillar).
. But my headliner's edges are torn to hell... typical wear and tear I guess? 2. Open the hatch.
3. Remove the sun visors.
4. Remove the dome lamp housing.
5. Remove the a-pillar trim panels.
6. Remove the cargo area side trim panels.
7. Loosen the seat belt escutcheons.
8. Slide the seat belt downward.
9. Remove the push-in retainers from the headliner panel.
10. Pull on the headliner panel in order to remove the panel from the roof panel.
11. Slide the seat belt through the seat belt slots.
12. Remove the headliner panel from the car through the hatch opening.
2. Open the hatch.
