Disconnect auto head light feature...
feature...
I've heard there is a sensor in the dash that triggers your head lights to turn on at dusk... But I find that they turn on way to soon. I would like to control this manually.
Any suggestions?
2000 TA
All of them received DRLs (daytime running lamps, via the blinkers) though.
If you do it this way (or even if you go to the trouble of soldering) there will be no side effects. Everything will work exactly as it did before except that your headlights won't turn on unless you turn them on with the switch.
There is also a picture there that shows exactly what to do.
Hell I didn't even know they came with auto headlights, until reading the part about the Canadian Spec T/A's. http://xse.com/leres/ss/drl.html
I used the first procedure using a rocker switch to turn the auto lights on or off. When this switch is on the auto feature and the running lights are off and now the headlight switch works as manually. If you use an LED switch you're going to need a relay because of 2 different voltages
Jumping across the sensor wires doesn't give an on or off option.
Wiring a switch across the sensor wire give you the option but there's
a 20 sec. delay when the sensor is turned on and a 34 sec. delay before the lights go off
This is what my switch looks like. The other button is for my garage door opener
This is a pic of my low beams staying on with my brights. I think only Pontiac's had this feature. I can also turn my fogs on or off
https://ls1tech.com/forums/stereo-el...same-time.html
I used 12 ga. wire as a jumper to match the factory wires and 12 ga. tap ins that I got from Radio Shack. They come 4 yellows in a package.
I needed a Phillips screw driver and a 7mm socket to take off the first cover under the dash. And then there was a second cover held in with 4 push pins at the rear and held on to the front by tabs that went into slots. I think I'm remembering this right.
