how to wire dvc sub at 4 ohms?
If it is 2 x 2ohm then you can wire it like this to achieve your 4ohm load:
http://a248.e.akamai.net/pix.crutchf...2-ohm_mono.jpg
If you have a 2 x 4ohm then you will not be able to wire it to a 4ohm load. Only a 2ohm or 8ohm load.
You can also turn down the gain on the amp so that you are not pushing the sub as hard even at lower impedance levels. So even at say a 1ohm load, if the amp is not at full gain you will not be pushing the sub or the amp as hard and save your sub.
One thing I am concerned about is if I take a hard left turn I don't know if the box/sub will stay put in that little cubby lol. I'm afraid it will fly out into the hatch, since there isn't much holding it in place other than a small piece of trim. Maybe I'm just being crazy though?
