speaker issues???
Old Aug 25, 2011 | 08:14 PM
jameswoodlee's Avatar
Default speaker issues???
Does anyone know if anyone makes the backing that goes behind the speakers in the doors in a camaro? I have a 99 SS and its like cardboard or something that water can seep down into and basically rots it out. does n e one know where I can get this part at? or does anyone have a mock up or something they have used?? your door speakers mount to them and when its rotted its a pia to get it mounted to it otherwise.
let me know thanks
Old Aug 27, 2011 | 01:44 PM
leadfoot4's Avatar
At least in the mid-90s cars, the factory installed a semi-circular "baffle", made out of plastic, which would deflect any water off the speaker, if it came down through the upper window channel. If your car is missing these, you can purchase a plastic foam type of "enclosure" from the aftermarket car stereo houses. These are made by an outfit called 'XTC'.
Old Aug 27, 2011 | 07:27 PM
yea ive hought of getting a set of those but i still need something to mount them to. its like a big hole in the door and then cardboard that its mounted to. i hate to try and rip these out of a car at the junkyard hoping someone has ran into this before
Old Aug 28, 2011 | 12:31 PM
leadfoot4's Avatar
Would it be safe to assume that you're not the original owner of your car? In my case, I am, it's a '96, and I can assure you that there's no "cardboard" used anywhere in my doors.
Just for reference, in my car, this plastic baffle I'm referring to is attached to the door with 4-5 sheet metal screws, and extends into the door by about 2.5-3". The speaker attaches to the door with 4 screws that go through the perimeter of the speaker, through this baffle, and into the door frame.
The "big hole" you're referring to should be approximately 5.75-6" in diameter, unless somebody hacked the door, in an effort to install something larger than the OE 6.75" speakers.....
Old Aug 28, 2011 | 05:07 PM
not the original owner ill try to take a pic and show u what Im talking about
Old Aug 28, 2011 | 05:41 PM
leadfoot4's Avatar
There's an ongoing discussion in this section of the website, and it's entitled CDT from KEE Speakers Installation, or something like that......
On the first page of this discussion, there are a few pretty good pictures of what an aftermarket speaker looks like, in the stock location. In one of the pics, you can see the plastic baffle I'm referring to.
I suggest you take a look there.
Old Aug 28, 2011 | 08:34 PM
yep i see exactly what u r saying now mine doesnt have that plastic baffle it has some sort of cardbaord thing that obviously doesnt work. do u have n e idea where I can get the plastic piece at??
thanks again
Old Sep 1, 2011 | 04:17 PM
leadfoot4's Avatar
thanks again
Have you found any of these baffles? If not, PM me......
Old Sep 1, 2011 | 04:31 PM
KEE AUDIO's Avatar
I sent him several links to them on eBay but if a member has a set on here please contact him so he can get a set.
I have one mount but I use it to test fitment of speakers I use in our cars to make sure they fit properly. 2 sets of Firebird and 1 Camaro mount.
Old Sep 1, 2011 | 06:30 PM
yes i have a set on the way someone on here is sending to me
thanks for ur help
Old Sep 2, 2011 | 01:11 PM
KEE AUDIO's Avatar
That is great!! I would prefer someone from Tech was able to help you vs. someone random on eBay. Keep it in the community!
Old Sep 3, 2011 | 01:43 PM
do the rears have the same mounting? I dont have anything on the rears they are just mounted to the metal behind the molding
Old Sep 3, 2011 | 03:11 PM
leadfoot4's Avatar
The rears just mount to the sheet metal, using speed clips, or whatever you call those threaded "thingies"...
