Viper 5902 Alarm Walkthrough please
Can anyone that has experience in installing the Viper 5902 or 5901 alarm give me a walkthrough on how to install the alarm on a 2001 Camaro?
I'm currently in Europe working and I fear that local shops will not be able to get the alarm installed.
I bought a Viper 5902 alarm with remote start, I have the bypass module for the VATS, and relays that are needed for the wires. I also have the wiring diagrams but I need instructions.
Thanks in advance to any help!
I have the Viper schematic wires and I have scanned them with my iPhone:
Here is the link
http://www.mediafire.com/?2qn135u3n4j4u50
And this is the wiring for the car that I found from Bulldog...can someone tell me which wires from the car connect to which ones from the alarm?
MODEL YEAR(S)
CAMARO 2000 -2002
KEY T-HARNESS IMMOBILIZER
N/A N/A GM'S VATS ANTI-THEFT SYSTEM, See NOTE #1
PART COLOR LOCATION DIAGRAM
12 VOLT CONSTANT RED (+) @ IGNITION SWITCH HARNESS
STARTER YELLOW (+) @ IGNITION SWITCH HARNESS
STARTER 2 N/A
IGNITION 1 PINK (+) @ IGNITION SWITCH HARNESS
IGNITION 2 N/A
IGNITION 3 N/A
ACCESSORY/HEATER BLOWER 1 ORANGE (+) @ IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 2 N/A
KEYSENSE N/A
PARKING LIGHTS ( - ) BLACK/WHITE (-) @ BCM, BLUE Plug, in PASSENGER KICK
PARKING LIGHTS ( + ) BROWN (+) @ BCM, BLUE Plug, in PASSENGER KICK
POWER LOCK RED/BLACK (TYPE B) @ BCM, in PASSENGER KICK
POWER UNLOCK TAN and GREY/BLACK, (TYPE C), See NOTE #2 @ BCM, in PASSENGER KICK
LOCK MOTOR WIRE N/A
DOOR TRIGGER GREY/BLACK and BLACK/WHITE (-) See NOTE #3 @ BCM, in PASSENGER KICK PANEL
DOMELIGHT SUPERVISION GREY/BLACK and BLACK/WHITE (-) (Requires #775 relay) @ BCM, in PASSENGER KICK PANEL
TRUNK RELEASE BROWN (+) @ BCM, BLUE Plug, in PASSENGER KICK
SLIDING POWER DOOR N/A
HORN BLACK (-) @ STEERING COLUMN HARNESS
TACH WHITE (AC) @ PCM, BLUE Plug, See NOTE #4
WAIT TO START LIGHT N/A
BRAKE LIGHT BLUE (+) @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM DISARMS WITH FACTORY REMOTE CONTROL ONLY
ANTI-THEFT 2 THIN WHITE wires in ORANGE Tubing VATS (PASSKEY) at STEERING COLUMN
NOTES
NOTE #1: If vehicle is equipped with PASSKEY/VATS, Ignition Key will have a little Chip
on the Steel Shaft of the Key that can be seen. Requires 791 Bypass Module
for Remote starting
to order go to the SECURITY BYPASS MODULE Page on this website.
NOTE #2: The TAN wire will UNLOCK the DRIVERS door and the GREY/BLACK will UNLOCK the
PASSENGER door. Both wires must be wired in as a TYPE C SYSTEM and use a relay for
each wire.
NOTE #3: This vehicle uses (2) separate door triggers wires, when installing a ALARM SYSTEM
use both wires and DIODE ISOLATE.
NOTE #4: The PCM (Power Control Module) is located under the hood on the PASSENGER inner
fender at the FIREWALL. On the V-6 the TACH wire is located in Pin 54, and on the
V-8 it is in Pin 10
Here is the link
MODEL YEAR(S)
CAMARO 2000 -2002
STARTER 2 N/A
IGNITION 2 N/A
IGNITION 3 N/A
KEYSENSE N/A
LOCK MOTOR WIRE N/A
NOTES
for Remote starting
each wire.
V-8 it is in Pin 10
Honestly, if you do not know what your are doing with it, pay a professional. I was an install manager for 8 years and my newer guys were never allowed to touch alarms, much less anyone who never had training on them.
As I said in the first post, I am in Europe and they do NOT have any experience with this car or this type of alarm...
But anyways, after 3 dreadful days of work, I have it almost done...the alarm is connected, remote starter works and I'm almost done installing the voice module...
The hardest part were the relays..
I have one question...can anyone tell me which wire is the accessory wire at the ignition switch harness??? It says ORANGE online, but all I find is a YELLOW -starter RED - hot all time PINK - hot at ignition and BROWN - hot when you turn the key backwards (radio works) and no orange.
My problem is that when the car remote starts, the heat is not blowing even though it is on... anyone know anything about this?
