Correct Sequence for Electrical Grounds
Old Nov 6, 2011 | 02:56 PM
FasTimeSS's Avatar
Default Correct Sequence for Electrical Grounds
Greetings,
I've moved my battery to the rear of the car with a 1' chassis ground in the rear trunk. up front i have the engine block grounded to the chassis. Everything is A okay except my hptuners is dissconnecting at WOT causing me to think that its a ground issue. Other than that the car starts and runs fine. Am i missing something here?
Old Nov 8, 2011 | 01:32 PM
FasTimeSS's Avatar
i guess no one knws electrical?
Old Nov 8, 2011 | 01:59 PM
38DD2436's Avatar
Run the battery ground to the block and not the trunk. Should solve your problem
Old Nov 8, 2011 | 07:14 PM
farmington's Avatar
As long as you have scraped the paint away where the cable ends touch the sheetmetal, your setup should be fine. I've done the same thing on other cars and never had an issue.
Old Nov 11, 2011 | 10:36 PM
Mike52's Avatar
Take 38DD's advice, it's always worked. Electricity takes the path of least resistance, a welding cable to the engine (I like connecting it to a starter mounting bolt) works a LOT better than a sheetmetal trunk floor.
Old Nov 12, 2011 | 11:13 AM
FasTimeSS's Avatar
i will try that, but ive read ur ground shouldnt be over 3ft long. with the battery being in the trunk that would make it over 7ft
Old Nov 12, 2011 | 07:21 PM
Mike52's Avatar
That's not true if you're using the appropriate sized cable, back in the '60s-'70s, when we put the batteries in the trunks of our Super Stock Plymouths we ran the negative cables (welding cable) all the way to the starter mounting bolts, really helped the high compression Hemi's to start easier. If you're using rubber or poly engine mounts you also have to be sure to attach ground cables from the engine to the frame. We were using front and mid engine plates bolted directly to the sub-frames so that wasn't an issue.
Old Nov 13, 2011 | 09:20 PM
FasTimeSS's Avatar
sweet well i will try that then so i can run (0) zero gauge wire from the trunk to the starter? or should i go smaller?
Old Nov 19, 2011 | 12:17 PM
AZ2ENVY's Avatar
0 gauge will be fine .
