A/c problem
Old Jul 18, 2015 | 10:44 PM
Karczewski's Avatar
Question A/c problem
Ok so today I get in my 02 ws6 and the air(hot or cold) won't blow out of any vent.. What do I need to do/check?? Cuz it's like 90degrees here and boiling lol.
It worked yesterday, but now and again the low fan settings would have take a while to kick in if I had it set on high at first.. Suggestions?? Just put in a touch screen and now this happened :/
Old Jul 19, 2015 | 10:05 AM
FraziaFraz's Avatar
a/c not blowing out of the vents is usually a vacuum leak. sounds like something came disconnected. my car would only blow out of the floor vents until i found the line that came unhooked. I recommend retracing your steps and seeing if you knocked anything lose.
Old Jul 19, 2015 | 10:34 AM
Karczewski's Avatar
Could it be behind my stereo?? That the only thing I really messed with.
Old Jul 19, 2015 | 12:35 PM
Karczewski's Avatar
This is the only thing that has no where to plug into?? What is it??
Old Jul 19, 2015 | 01:22 PM
FraziaFraz's Avatar
Hard to tell what that is. That could just be wiring for an option your car didn't come with ( traction control or second gear switch etc.) I would start by checking vacuum lines. They are old and constantly exposed to heat. They get brittle and can break suddenly. There is a point by the ac compressor where 3 lines meet. I would start there.
Old Jul 19, 2015 | 01:35 PM
Karczewski's Avatar
Alritey, I'm trying to avoid going to my mechanic lol. Ever since I've joined this site I've learned so much from everyone!
The compressor on the passenger side??
Old Jul 19, 2015 | 01:43 PM
Karczewski's Avatar
If what I was looking at was correct then there's no hoses missing...:/
Old Jul 19, 2015 | 02:00 PM
98CayenneT/A's Avatar
I do not think it is a vacuum leak. Check the blower motor relay. Also you could pull the blower motor out and hook it up to a outside power source and see if it blows
Old Jul 19, 2015 | 02:01 PM
FraziaFraz's Avatar
I'll post up some pics of where the lines are in a bit.
Old Jul 19, 2015 | 09:53 PM
Karczewski's Avatar
Ok thanks yall!!
I was busy doing yard work today but I'll give my blower a check after work tomorrow also, isn't that located behind the glove box??
Old Jul 20, 2015 | 07:21 AM
WhiteBird00's Avatar
Ungrounded Moderator
Have you checked the HVAC fuse (20 amp fuse #6)?
Old Jul 20, 2015 | 08:00 AM
Karczewski's Avatar
Yeah, one of the first things checked
Old Jul 20, 2015 | 07:25 PM
Karczewski's Avatar
The blower is working, took it out and hooked it up to a battery.. So it's not that.. Is there any possibility I knocked something loose behind my CD player?? I've checked it a hunted times but didn't see anything
Old Jul 20, 2015 | 08:36 PM
FraziaFraz's Avatar
Are you sure it's blowing out of none of the vents? Turn it on and see if the a/c is blowing out the floor vents.
Old Jul 20, 2015 | 08:48 PM
Karczewski's Avatar
Yup I'm sure. Not blowing out of anything.. I did see however that the black wire from the stereo are spliced together into the harness, shouldn't one be grounded?? Can that be the culprit?? I'll post a picture tomorrow cuz I don't think I can exain it rite
Old Jul 21, 2015 | 07:11 AM
Not necessary. The black wire in the factory radio harness goes to ground. So if the head unit and any accessories like a steering wheel control adapter are spliced to the black wire in the harness then they already go to ground.
There is very little you could do when replacing a head unit that would cause a failure of the HVAC system. About the only thing I can think of is possibly disconnecting the plugs on the HVAC controls below the head unit opening. For example, if you unplugged the fan switch then you wouldn't get any air movement.
Old Jul 23, 2015 | 06:03 PM
Karczewski's Avatar
Okay, I got it to work!! Boo us!!
But know I. The midst of all that it will only blow threw the defrost and feet.. That's the default position I take it.. Now what?? Leak somewhere?
Karczewski's Avatar
Btw: thanks to all of you for the help!!
Old Jul 23, 2015 | 06:58 PM
FraziaFraz's Avatar
If it's only blowing through the defrost and feet then that IS the vacuum leak I was talking about. Common issue. Small plastic lines exposed to high levels of heat over a 15 period. They break. The valve that switches the ac from floor to the front vents is vacuum operated. If the is a leak. It won't switch.
Old Jul 23, 2015 | 08:46 PM
FraziaFraz's Avatar
The vacuum lines you want to find are located behind this mess on the passenger side of the engine bay.
Look behind the wire looms and you will find this plastic piece with 3 vacuum lines that run in/out of it. Trace them to your problem.
