DDM tuning HIDs not working
Old Dec 29, 2015 | 02:56 PM
Sail Hatan's Avatar
Default DDM tuning HIDs not working
Just took them new out of the box and neither works. 2000 Camaro.... Was wondering if the running lights have anything to do with it? Tried it on both high and low beam spots, Incase I ordered incorrectly. Anyone have any insight?
Old Dec 29, 2015 | 06:14 PM
stealth355tpi's Avatar
If neither side works, check the polarity.
Old Dec 30, 2015 | 05:55 AM
Sail Hatan's Avatar
Idk what that means? Don't they only go one way?
Old Dec 30, 2015 | 09:44 AM
Daniel Richards's Avatar
YES, they only go one way, when you plug the wire harness from the car into the HID ballast if the positive and negative are backward it WON'T WORK, this is the first step in a HID Troubleshoot for not working.
Old Jan 19, 2016 | 02:43 PM
imma_stocker's Avatar
Turn the plug around, that's the only way mine work. Then electrical tape wrap since the clips will be backwards.
Old Jan 24, 2016 | 07:14 PM
johnny6's Avatar
Yep, just did this the other day
Old Jan 24, 2016 | 10:22 PM
SparkyJJO's Avatar
On my old car I repinned the connectors so they weren't reversed anymore (thanks GM).
On my current car I used a relay harness so it no longer mattered.
Old Jan 27, 2016 | 10:46 AM
necrocannibal's Avatar
I had the same issue. Thought they sent me some bad ballasts or bulbs and just for the hell of it I turned the plug around and voila, I had lights.
