sound deadening
Old Jan 28, 2016 | 07:00 PM
george88gta's Avatar
Default sound deadening
OK, here is the situation. Car is an 02 TransAm convertible. I had the differential gears replaced with Motive Gear 3.70 gears ( street gears , not the performance gears). Car is a bit noisy. Had the work checked by a couple of shops and they all say noise is within normal range. Now I have purchased a set of Kee stage 2 speakers. So while I have the car apart, what sound proofing will work best to help reduce the gear noise and make for a better speaker upgrade? Kee suggests the Quick Roof, but I wonder if it will have a tar smell. Obviously, riding with the top down eliminates the gear noise, but here in the Northeast, it does get cold.
Old Jan 28, 2016 | 07:03 PM
EdgarB's Avatar
Vert owner here as well. I am having good luck with Peel and seal believe it or not lol. I have had no issues with the smell but I have only done the trunk area.
Old Jan 28, 2016 | 07:15 PM
Good info, thanks. But since the Quick Roof is only 6 inches wide it may be a chore to use on the floor. Does sound like a good choice for the doors and quarters.
Old Jan 29, 2016 | 05:48 AM
Atrus_SS's Avatar
I used sound deadener showdown tiles, locally procured closed cell foam, and "home depot" MLV. I still have to do the cabin floors, but I've done the trunk and doors and it definitely made a difference. It's not a bank vault and never will be.
The car feels much more solid, I get far less road noise. Overall, I say it was worth the time and money.
Read a bit online and you'll see that throwing some dampening product isn't the end of it, nor do you need 100% coverage. I did end up purchasing from him, but sounddeadenershowdown has a very nice writeup on how to properly sound deaden a car - I read a TON elsewhere online that corroborated his methods.
Not sure if it's allowed to link this or if this would be viewable to non-members, but here's my writeup..not too many pics, but some information on what I did and what I used: http://www.mifbody.com/vbulletin/sho...l=1#post921157
Old Jan 29, 2016 | 03:19 PM
ATXSS's Avatar
I used the Home Depot and Lowes peel and seal and there is ZERO tar smell. Even in a hot Texas summer I didnt smell a thing. It really helped with the stereo, especially the sub. My 3.73's whine alittle bit too and it did help deaden that but not much. DO IT
Old Feb 4, 2016 | 04:39 PM
M4N14C's Avatar
Don't have a vert but I did this a while back:
https://ls1tech.com/forums/stereo-el...-trans-am.html
I used some actual sound deadener and it helped out a lot, does burn up a LOT of time though so plan on doing it over a weekend...
Old Feb 6, 2016 | 05:33 PM
Couldnt get the write up's to open, but I get the idea. Guess I should set aside more than a few days for this. Garage stays around 60 degrees so I should be OK. Thanks for the info.
Old Feb 7, 2016 | 12:46 AM
98RaptorTA's Avatar
I posted some pictures of my sound deadening in my post here (Post 21 in the following thread):
https://ls1tech.com/forums/appearanc...-interior.html
I used a lot of FatMat. For the amount of sound deadening I wanted, the Home Depot products was not practical. I covered every spot of metal on the interior; floor, roof, pillars, etc. I replaced the carpet and then took it out as it was really thin and cheap. So I have better quality carpeting with mass backing that I will be installing soon. I have added some carpet padding in certain areas as well. It made the car really solid and quieted it down a lot. It will probably do more as well once I install the good carpet.
