Turn Signal Issue.
Recently ive been having an electrical issue regarding the turn signals.
When I start the car, every light works fine until I use either the left or right turn signal. They work and flash but it returns back to a steady light. One is on the other off. From time to time they switch off. I recently switched the relay fuse because it was worst with the old one but the problem is still there. Whats the next thing I should look for or change or check?
What happens when you use your hazards? What happens when your headlights are on?
Do you mean that you switched the flasher? If so, did you replace it, or switch the left and right ones under the dash? If you replaced it, what did you put in there? (The part number and type makes a big difference.)
Since your problem seems to involve the switching between turn signal and DRL and is intermittent, I would suspect that one or both of the two switching relays inside the DRL module may be failing. They are not serviceable and the whole module is expensive ($400 retail, $260 online) but I've seen them on eBay for $30. The part number is 10407669.
When your turn your turn signal on, with the headlights off, what does the front light do, what does the rear light do, and what does your dash indicator do?
Are you saying that when you use the hazards, the lights work normally and then the DRL's both come back on like normal? Do you only get the one DRL on and one DRL off after you use the turn signals?
When you replaced the flasher, what did you replace it with. (Model number and type.) Are you sure you replaced the turn signal flasher (on the right side of the driver's legs) and not the hazard flasher? (to the left side of the driver's lets)
The DRL module is a black box about the size of a pack of cigarettes mounted to the defroster duct behind the radio (pull out the radio and reach through the opening to get it). But don't replace it until you've eliminated all the other possibilities.
I replaced it turn signal flasher with the Novita/Hazard Warning Flasher from autozone, Part Number: LF12.
When I use the hazards the lights do work normally but they dont come back to normal. its stays the same as the picture above. a few minutes later it comes back to normal.
If so ^ that's confirming that the DRL module is likely the culprit. (Probably a bad capacitor on the board, or something like that.)
Yea. I use it. One goes out for a several minutes then returns to normal.
So I guess Ill have to replace that module that was mentioned above. Ill see if I can find someone who is parting out a car and get it from them. Thank you for your time and valuable information.
This thread shows what the board looks like, on a unit that does have a terminal condition: https://ls1tech.com/forums/stereo-el...l-problem.html
The horrible thing about this is that the part is expensive, but the individual components on the board are worth less than $12.50, all together.
