Swapping over to fixed antenna...
Here's the hardware layout:
Power antenna hardware
Fixed antenna hardware.
You'll see that the fixed antenna has a bracket with a basic threaded post (#3) mounted with a bracket so that it protrudes through the quarter panel and rubber grommet (#2) so that the fixed antenna mast simply screws onto the post. The power antenna has a collapsible mast which retracts into the motor assembly with no external threaded post to attach a fixed mast to.
You would need only the fixed antenna bracket (part #10425534) - the grommet is the same for both types - but it has been discontinued so you will probably have to get one from a junk yard.
I'll need to attach that to the top of the inside of the bracket, then add my stubby, if i'm correct.
I got mine (with the fixed external antenna, as it is sold as a unit) from Hawks Motorsports.
