Rewiring a switch: Can it be done?
I believe it would be a "On-OFF-On" or "3 position single throw switch" you can buy them up to 50A I'd check the draw on the light and just size accordingly..
If its over 20A I would consider a pair of relays. (1 per switch. )
Check sources like Mouser. Nothing causes more issues than cheap electrical parts..
You may lose the memory capability if it is built-in to the switch module but I doubt it. All of the strobe light modules I've installed have had the memory in the light module rather than the switch... many don't even come with a custom switch included yet still retain the selected mode between uses.
Wiring with aftermarket switches should be easy. The light module can actually be grounded (black wire) anywhere convenient such as a bolt near where it's mounted - there is no reason the ground has to be run back through the relay or switch. The power wire (red) is the one which must be switched. Depending on whether you want to be able to use the light with the ignition off, you can connect a toggle switch to battery power or to an ignition switched power source. The yellow mode wire is the tricky one. It can be designed to trigger a switching modes based on being grounded or on having power applied. It would be best to find out from the manufacturer (if they will tell you) but you can always test it by powering on the light and then touching the yellow wire to ground (ALWAYS use ground for the first test because it won't damage the light if it's the wrong choice). If the mode changes each time you touch the yellow wire to ground then you can simply connect the yellow wire to ground through a momentary switch. If the mode doesn't change then try the same thing only applying power to the yellow wire momentarily to see if that makes the mode change. Then you can wire the yellow wire to power through a momentary switch. It's really a 50/50 shot whether the mode switch yellow wire requires ground or power - I've seen them both ways. But again, ALWAYS try ground first!
The light requires continuous power to stay on - it will turn off as soon as you take away power - so a momentary switch can't provide that by itself (unless you want to hold the switch for the entire time you want the light on
). You'll need a latching relay or a module to convert a momentary power signal into a continuous power supply for the light.Latching relays are a good choice if you are able to provide two different signals (one for on and one for off) or you can reverse polarity of a single input (for example, power for on and ground for off). That would involve some tinkering to get it to work in this case. One way would be to use that switch you have but wire it so pressing one way turns on the light - latches the relay - and pressing the other way turns off the light - unlatches the relay. Then you would still need a separate momentary switch for mode selection. Many latching relays are electronic devices designed for circuit board installation but there is an enclosed 12V latching relay module that provides 8 amps of output and is very easy to set up. It costs $21 on Amazon... search for "latching relay 12v dc".
An alternative is a trigger module like the PAC TR-7. It provides many useful functions but the one you would use in this case would be the latch and unlatch function (#3). This lets you have a single trigger pulse turn on a steady power output and a second trigger pulse on the same input turn off that steady power. That would allow you to use your switch for both power on/off and mode select. You could press once on the I side to turn on the light and press again to turn it off, leaving the II side for changing the light mode. The module costs almost $30 on Amazon but doesn't produce enough output to directly power the lights... you would still need to add an ordinary 30A automotive relay to provide enough current (the module would be wired to trigger the relay). Personally, I think this is the more elegant solution because it uses only the single switch you already have but it involves a little more wiring behind the scenes. Let me know if you go this route and I can assist with the wiring if you like.
Thanks again for the information.
This is what I've got so far in trying to figure out how to wire it up to have the option of having the light bar by itself, or light bar with flood lights at the same time. In the diagram below, I've added a second relay to power the flood lights. A few questions...For now, I'm assuming the yellow wire going to the momentary switch grounds to activate rather than goes to positive. I am assuming if I splice the yellow "mode" wire so that it runs to both sets of lights it won't harm the flood lights for the "mode" button to be spliced in even when the flood lights do not have power going to them (not lit). Also, I can't figure out how to splice the flood lights into the SPDT switch so that when the switch is in one position they all come on together and when it's in the second position only the light bar will come on. So far any way I've thought about it will cause all the lights to come on when the SPDT switch is in both positions, so I know my SPDT wiring shown below isn't correct. I'm not sure how to wire that part, but I feel like changing to a DPDT switch will allow this, I just can't figure out how. Also, I'm still confused by all the ground wires coming from the lights that are running back to the relay.
OR energize red and it turns white ,, add power to the yellow wire and you can flash it.
I'd open up the switch module and see if there isn't a small IC in there that's doing the switching for the flashing modes..
The relay in the original package is likely a SPDT like a standard Bosche possibly with a latch circuit. (If its got the same numbers on the bottom and 5 terminals its prob a bosche or a bosche clone.
The grounds are wired like they are likely because the most common cause of lighting problems is a bad ground, bring all the grounds to a singal (-) and no ground problems.
There are a ton of small COBB style Led combinations,, 1 color/2 color/tri-color combinations are endless.
Good luck!
4 terminals is a standard spst relay.. "normally" so that really makes me think the flash is all being done in the switch "pod"
2 pins for the relay activation and 2 pins for the circuit your switching.
If you hook everything up at the bench using the factory harness, what does the mode button do? Does it cycle through all combinations of the light bar and flood lights and also of the colors and strobe effects? Or does it only cycle through colors and strobe effects, expecting that all of the lights will be powered all the time? Have you actually tested the light bar by itself without the flood lights connected to see if the modes still work? If you can apply power and ground to the red and black wires of the light bar and then change modes by touching the yellow wire to ground then you know there is nothing special about the included switch module. You can do that at your battery using jumper wires with alligator clips. If it doesn't work then you'll know that the "intelligence" is in the switch module rather than in the light... although every one I've worked with has always had the intelligence in the light and not in the switch. That allows using switches other than the one that comes with the lights.
If the switch module really is the controller then I suppose one possibility would be to open it up and connect the wires for your own switches to the built-in switches in the module and then hide the module under the dash somewhere.
