rear window defroster problem
Old Aug 15, 2004 | 06:49 AM
99z284speed's Avatar
Default rear window defroster problem
My rear window defroster sucks. I get in my car and start it, push the rear defrost button and the button lights up, but only stays on for a lil bit. It barely starts to work and then shuts off. and it won't go back on for a couple of minutes.
any suggestions?
Old Aug 15, 2004 | 10:54 PM
01 Red WS6's Avatar
Mine does the same thing. I want to know whats up with it too. Does yours sound like it clicks when you push the button after it cuts off? Mine does but it still doesnt work
Old Aug 16, 2004 | 06:43 AM
yep same thing
Old Aug 18, 2004 | 01:22 PM
01 Red WS6's Avatar
come on someone has to have had this problem besides just the 2 of us
Old Aug 18, 2004 | 01:36 PM
badjuju342's Avatar
Deranged Rat Fink
try this: unplug the connectors at the rear window. the two terminals attached to the glass , check for continuity with an ohmmeter , if you have infinite resistance, you have a broken grid (the little lines in the glass ),also visually inspect the lines in the glass for broken lines . might even be metallized window tint causing the problem . GM does have those on a timer that shuts it off after a little while , might end up having to live with it.
Old Aug 18, 2004 | 03:09 PM
felton316's Avatar
any suggestions?
The breaker (the silver guy in the fuse box) that GM used were of very cheap quality. Remove it and replace it with a better one or just put a fuse of the same amperage in its spot. I did this two years ago and its worked ever since. The timer will still work also.
Old Aug 18, 2004 | 04:05 PM
01 Red WS6's Avatar
could the timer be bad? Where is it at? I was talking to a friend and he thought it could be bad if it had one.
Old Aug 21, 2004 | 09:19 PM
02blackZ's Avatar
I turn mine on and it shuts off after a few minutes and then my power seats don't work either for the same time. I try to work them a few minutes later and they come back on. Weird!
Old Aug 21, 2004 | 10:49 PM
2000TransAm24's Avatar
I agree with felton316. I have had the exact same problem as all of you have described. Its nothing more than that stupid silver breaker. Annoying as hell in the winter time.
