Steering wheel controls & new head unit
I was wondering if there are any aftermarket head units that will work with the steering wheel controls. if so which ones.
I dont think so try doing a search.they do make a unit that plugs into the control cable and then sends the signal via infared to the aftermarket unit allowing you to use wheel controls.
Ls1tech Bad Ass
Originally Posted by TA TED
As long as your deck has an infared remote control, you can use an interface device called a PAC SWI-X. You can order it from Crutchfield.
Ls1tech Bad Ass
best buy has them for like 50 or 60 bucks... i just thought id check it out when i went into work tonight. not sure how prices compare to other places or whatever... just FYI.
Will best buy also install the infrared remote control? I have the ability to do it myself but would like to have it all professionally installed so i have reciepts.
Ls1tech Bad Ass
yea best buy can install it (at least our shop can... i would know... i work in it )... i can quote you a price later on, not sure what'd it be off the top of my head
does it require cutting stock wires? i really don't like that idea. is there anything you can buy to just plug stuff in with? the most i would do is use splice connectors, but if it requires cutting factory wires in half, i'm not to fond of that.
