Where do I get this light bulb??
Old Feb 4, 2005 | 11:31 PM
01 Red WS6's Avatar
Default Where do I get this light bulb??
I replaced my driver side door panel today and when I put everything back together I noticed the light on the trim piece by the inside door handle quit working. I pulled it out and it would flash on and off. I thought one of the wires was broken so I started looking and the wires looked fine but the bulb would work and then flicker then quit. Finally it quit all together. I checked the bulb and it was out. The filament is broken. Its a small little bulb and I don't know what the # is or if I can even get it at the autoparts.
Also if I can replace it how do I get it out without breaking it?
Thanks
Old Feb 5, 2005 | 12:14 AM
LS1_SS's Avatar
your in luck, I took one out of my HVAC, I think its the same light. PM me your adress and Ill mail it in the morning.
-Nathan
Old Feb 5, 2005 | 02:04 PM
WhiteBird00's Avatar
Ungrounded Moderator
It should be a #74 bulb.
Old Feb 6, 2005 | 09:15 PM
01 Red WS6's Avatar
Thanks to the both of you for the response
Old Feb 6, 2005 | 10:53 PM
LS1_SS's Avatar
mailed it out yesterday morning....
-nathan
Old Feb 7, 2005 | 09:26 AM
01 Red WS6's Avatar
Thanks Nathan I owe you one
Old Feb 7, 2005 | 12:11 PM
mike s.'s Avatar
They are defintely 74's like he said above, I had the same problem when my gear inducator light went out, I got mine at Autozone for $1.50
Old Feb 7, 2005 | 12:31 PM
01 Red WS6's Avatar
was it hard to pull the old one out? Mine is stuck in there really good. I don't want to break the thing off in there but I can't seem to get it out
Old Feb 7, 2005 | 01:34 PM
LS1_SS's Avatar
I broke the first one trying to get it out, theyre in there good so chances are you will break it. If you do you can pull it from the metal inside the light, its in there really good so the light should come out that way.
Old Feb 8, 2005 | 12:13 AM
01 Red WS6's Avatar
I'll give that at try thanks
Old Feb 8, 2005 | 08:41 AM
mike s.'s Avatar
It will pop out, use a good pair of tweezerz and yank it out by the filament if its broken.
Old Feb 16, 2005 | 08:54 AM
01 Red WS6's Avatar
ok I got around to pulling it out yesterday. I broke the bulb (well I didn't break it my father did) That thing was in there good. Once it was broken I tried to pull it out by the filament and that broke off too. I ended up just breaking the bulb up till it all fell out. I'm thinking of swaping out the bulbs with some LEDs so I don't have to mess with this any more.
Old Feb 16, 2005 | 01:12 PM
LS1_SS's Avatar
I can get you some in red, white, or blue. I have them all in stock and can make them to fit that size. Let me know.
-Nathan
Old Feb 16, 2005 | 01:21 PM
01 Red WS6's Avatar
PMed you
