What Is Needed To Hook Up Amp?
What you need is at least an 8 guage power wire(depending on amp power) with a fuse holder, same guage ground wire, remote turn on wire, and rca cables is you have an aftermarket head unit. You also need speaker wire to run to your subs that you will get.
If you do not have an aftermarket head unit, youi either need an adapter that taps into your stock harness that gives you rca plugs, or a high level signal adapter that taps into your stock speaker wires to give your amp signal.
https://ls1tech.com/forums/wiring-stereo-electronics/272784-accessory-power.html
Also, (It won't hurt because the RCA's are streetwire brand) but the wire running between the RCA's wasn't meant for a remote turn on. You are safe doing it.
