New speaker suggestions
I would like to run the setup like this, if you have better ideas please let me know.
1 amp for 2 fronts and 2 rears
1 amp for the 2 subs( was looking at fosgates and W0's)
front tweeters and rear tweeters running off the head unit
All speakers are going in factory location.
Help on amps would be nice too? Looking for physically pretty small amps, I would like to have them both in the little area to the lower left when you open the hatch.
Also, can you get speakers for the front and rear that are not 2 way, since I will be running seperate tweeters anyway.
Thanks everyone.
Don't spend the money on the extra tweeters. If you get good Component speaks that would be enough. Like this.
http://cgi.ebay.com/ws/eBayISAPI.dll...749204622&rd=1
If you like the extra treble, most good brands have adjustments on the passive crossovers that allow you to adjust for extra sound throught them. Amp the Fronts of a good 2 ch, the rears off the Deck and an amp for the subs.
What kind of budget are you look at? PM or post it up. Can make the decicion easier. Can move the money around to spend it in the right areas.
Sounds like a good starting point but can probably improve it in some areas.
Also I vote for the JL's. They have always made a good speaker and they seem to be little better than the Fosgates at the same price range.
1.5 DIN reciever
Front component speakers alpine type-R SPR-136A
Rear hatch alpine sps-100a 4"
Sail panel subs jl 6w0
amp 6 channel jl audio e6450
I see that Kick Panels won't work well because your an M6. Try just Mid-range speakers in the sail panels, turned down a bit. That will help draw the stage upwards. The tweeter's should pull the stage alittle more forward.
If you have tweeters in the rear, it might the stage rearward to much. Treble is much more directional.
Thanks for the comments, i'm more of a home audiophile trying to do it in a car now. How do you think that six channel amp would work out for this setup?
IF you don't plan on competing, forget everything I just said. This was an experiment that worked out very well.
Proper tuning can raise your height to about dash level at best from my experiences in this F-body. Sounds like you've been given very good advice.
I definitely wouldn't recommend my set-up unless VERY SERIOUS about competition.
FYI, I angled my door tweets directly across from each other, as same for the pillar tweets. You'll have to experiment w/door panel tweeter angles.
Those door tweets will scream up at you, unless you re-direct. Hence, why I elected to bi-amp my tweeters/mids. WHAT WE REALLY NEED ARE KICKS!
Darn, M6's
Good luck!
If anyone has any info or is using this amp please let me know how you like it or if you think it will work for what im doing. Thanks.
Front - MBQuart 6.5" components (Q218)
Sub- JL Audio stealth box, 10" sub, dual voice coils
Front amp - JL Audio 300-2
Sub Amp - JL Audio 250-1
1 farad cap
NEO35 mp3, with 80gb hard drive
Alpine head unit
This system kills in my car, the clarity exceeded my expectations, and I've heard other , higher wattage systems that pale by comparison. And I still have T-Top storage.
pic
Sounds like you're taking a page from my book, but you'll be very pleased.
Dynomatting will definitely help to keep some of the road noise out. Good investment, but watch out for the added weight. (2) bulk packs and (2) door kits will add a tremendous amount of weight. Probably looking at 120# at MY dynomatting. Good stuff, but I needed an SUV for this project.
Last year, I competed in both SQ and SP formats, so this was a requirement for me. A personal decision.
Just a forewarning! Now I used Dynomat Extreme which is an asphalt-based product and is heavier than other Dynomat products. They claim Extreme is more effective on sound-deadening. Suggest you determine needs (sq ft) and then check it out. Then you'll have a ballpark idea of weight.
I have a question for you. I was looking at you cardomain posts(Very nice car by the way, I love firehawks), when you dynamated your doors, did you take that plastic off that is in there from the factory or put it over it, and do you use the dynamat inside the speaker housing as well(say like in the sail panels) or just around it? Sorry may seem like a dumb question but Ive never used this stuff before. My main reason for putting it behind the speaker in the sail panels is to stop the outside vibration sound on the sail panel.
Ok, I found the weight, 36square feet is about 30 pounds. Maybe be a little more weight than I want, think I might just do both doors and the sail panel area. Still need to know about putting it behind the speakers though, sounds like a good idea to me.
....thanks for the props. Hope that answers most of you questions.
Oh, sorry, yes, the midrange 6.5" is fastened to my MDF template, and the tweeter is fastened to the door frame itself utilizing 2-hole strapping material for easy adjustments (imaging) --- the speakers are not in the stock locations.
