3 way, 24db/octave crossover?
I want to bi-amp my setup but the crossover that came with the Infinity Perfects is a 24db/octave and I would rather not give that up. Help?
The decibel rating on the crossover has nothing to do with the efficiency or how loud the crossover is. The DB rating is actually the rate of decent at which the frequency rolls off. 99.9999999% of the people cannot tell the difference between a 18db and 24db roll off.
Im still unsure (from the other post) what this bi-amping is.
an amp (channel) for the tweeters, one for the mids, one for the subs.......no speaker level crossovers.....
so you think I should just go with the 18db?
I've seen Bi-Ampable component before. I can't recall a brand off the top of my head, but they work like this: You can have both the tweeters and the woofers running off of 1 input (normally how it's done). If you want to "Bi-Amp" it, you would usually clip a wire inside or remove a jumper. Then you can apply 2 sperate inputs. 1 set for the mids, 1 set for the tweeters. Crossovering? taken care of throught the regular crossover.
Oh..... OK. You meant "running the tweeters off another amp". I don't think there is an industry term for doing this.
You'd be fine with 18db. The reasoning behind Infinity using a 24 dB Slope is probably complex to explain.
If you really want to know PM me and I'll come up with reasons for this. It deals with Speaker Dynamics and design and is mostly physics based. I'll break it down so you can understand, but you would have to have a decint working knowledge of how crossovers work, nodes, dips, Speaker Materials, how a speaker works,.......
Easy enought to ask the specific question and trust that myself and 2much know what we're doing.
).....I'll just go with the 18db then......any company better than the others or does it matter?
Im sorry, but im failing to see the advantages of this...
