AMP has contant beep
PG tech support web site is http://www.phoenixgold.com/2004/techsupport.html
(-) terminals. Do I need to bump it down to 4AWG?
Disconnect the Speaker Wires and see if it get's hot again or has the alarm. If it does it's the Amp.
ALso that is a Throidal Choke not a Voice Coil. It looks like a Coil though. He told you to Put hot glue on it???? WTF? I'm assuming it's not warrantied. They would never tell you to open an amp up and DIY repair it if it was. Wierd. I'm suprised he told you to do that. Usually if it's loose it'll Hum not really sqeak. I'm going to lean towards a bad amp.
Also check around the transistor bank for excess heat or loose screws. They need to be snug. Around 40 In/lbs. So basically snug not cranked down hard. Try putting a screw driver on the screws and tighten each one a little. Should move.
If the transistor area is the other HOT part it could be a shorted transistor. That means the amp would have to be repaired.
Also, does it smell like ionized Air? Funky smells at all? Visible Burn marks?
Just be carefull around the Transistors. They have a Heat Sink Film on them to aid in Heat transfer. It's a bitch to get off you fingers. Time to take it apart and perform a close inspection. It's really hard to diagnose problem at a Component level over the net. I'll try and think of more tips for you.
Wait until you get to the easier Fixer-uper for cheap. Stuff like blown Ground straps on the Board from Wrong polarity Wiring, and Turned to far Potientiometers (gains) those are easy to find and fix. Could buy those amps from people and fix-em cheap .I still have 2 old Punch 150's like that. 1 was the Ground Fuse link on the board and the other was the pots. Bought both for the hell of it for about $30 and fix them both by learning the way you are.
The Area that is suspect right now seems to be the Power Supply. Something is Shorted causing it to draw large curent. That is why it's heating up. Try to narrow it down some more by powering it on and then seeing where the Heat build up occurs 1st. The Power supply area is easily identified by the Large Capacitors and the Throidal Choke. That seems to be it. I doubt the Output stage is at fault due to it actually playing. 1 unbiased amp and the stage goes down, or is really screwy. This is occuring without a load present. That changes the Function of the Transistors.
Just take a Good Visial Inspection. Smell the Board itself around the area. Caps have a super Distinct Smell when they go. Not like Ionized air. That means there is a Large amount of Current Leakage occuring. You smell it in a Computer now a days due to the small die size and the even larger amount of current leakage. That's the reason they run so hot. (CPU Chips)
Do a detailed Visial. Might find the problem that way 1st. Might even suprise yourself.
Every question you could want answered is in this. It's a lot to filter thru but may help you out in a bind.
http://www.allaboutcircuits.com/vol_3/chpt_4/2.html
I'll edit to give you more info.
Well. If you have a DVM just check to be sure it's ground. Just put 1 lead on the Neg term. and the other in the suspected spot. Those look more like Filtering Caps for the DC signal and not ment for large storage. Used for Filling in Dips. Basic Filtering.
Also if it's getting that hot it might be loosening the Soldiered joints. Just a quick heatin of them might help.
At this point it's starting to get closer to needing schematics, an O-scope and a DVM just to go deeper. I'll ask a Buddy of mine what he thinks. I'll get some info later on for ya.
EDIT. Hot glue isn't going to fix a loose Connection. If it's too loose the Current Leakage can be comming from that area. If you have a solidering iron, (sounds like it) just re-heat the joints on the Throidal. All +12vDC current goes thru the choke. It's kind of the Heart more literally like all blood goes thru the heart.
The 1 thing leading me to believe it's a short is that it's getting really hot. An open circuit doesn't really act in this manner. Not in a Power Supply stage.
