Question about 4 ohm speakers
Old May 22, 2005 | 02:59 PM
u8dusst's Avatar
Default Question about 4 ohm speakers
The speakers I want are 4 ohm speakers, and the amp I want is rated at 100X4 @ 2 ohm and 75X4 @ 4 ohm. So does that mean I have to find 2 ohm speakers to get the full 100 watts?
Here's the amp...
http://www.polkaudio.com/car/specs.php?name=c400_4
And here are the speakers...
http://www.polkaudio.com/car/specs.php?name=mmc6500
Old May 25, 2005 | 09:14 AM
prince xizor's Avatar
Another option is to get another set of 4 ohm speaker and wire them parrallel that would change the ohm load to 2 ohms.
Old May 25, 2005 | 11:17 AM
jimmy 2 Times's Avatar
then you cant fade, or balance the sound
Old May 25, 2005 | 05:09 PM
Richiec77's Avatar
Don't worry too much about the difference in volume between 2ohm and 4 ohm. It is Barelly noticeable (if you can hear it) and adds distortion by around a factor of 10x.
Also, the ouput specs for the rated ohm's are using Static resistance (think resistor) and don't take into Account the True nature of Speaker Dynamics.
http://www.lithosindia.com/Q-Balance%20Detail.htm
Look at the Curve on the Left. It shows the natural Sweep and not the Linear reponse you would think. Ohm's for a Speaker is an Average measurement.
So, All said and done, Just go ahead and wire it up for 4 ohm and you'll be fine.
Old May 25, 2005 | 05:11 PM
Richiec77's Avatar
Also. The curve will change depending on how the speaker is installed. (What type of cabinit, Speaker Wire, Connections, Joints.)
Old May 25, 2005 | 09:02 PM
u8dusst's Avatar
I really appreciate the reply, but you are going over my head here.
I figured id be fine if I wired for 4 ohm, but what im saying is, that amp will only push 75X4 @ 4 ohm, right? I basically want my music as loud as possible.
Old May 25, 2005 | 09:33 PM
2MuchRiceMakesMeSick's Avatar
Hes just saying to stick with 4 ohms because 25 watts wont make that much of a difference. Hes right but if you MUST get a 100watts cause you just want it then buy a bigger amp.
EDIT: Ooops. I hit Edit instead of reply.
Old May 26, 2005 | 01:00 AM
Richiec77's Avatar
Good Translation. I need to forget that Engineering crap when I'm on here
