Want a full system NEWB!!!
I'm looking to upgrade the stock monsoon system, completely, all new speakers, tweeters and amp.... then get the t-top box w/ 2 12's
Problem is i dont know what to get. I dont care to be best of show, just want a good sound that cna be heard clearly from a good sized distance.
So total that would be 10 speakers. So how many amps will i need? I was planning to use just 2 but i think i may need more
what would be a good upgrade maybe go to a 1000 watt amp to the speakers themselves. I was thinking of upgrading to the setup in the FAQ section but the Alpine 6.5's are 40 w RMS and i know i'd need more w/ the aftermarket amp. how should i do this? Any recommendations, part numbers to take itno account. I like Alpine alot, i hear good thinkgs of Cadence, Kole, Memphus, Infiniti as well, but iw as looking for all Alpine since i am getting the head unit.
I'm sorry i'm very complicated but i am a newb and need to get off on the right foot and almost be told what to do. I'm not looking for the show sto;ppper 155 db's or anythin....Thank you very much
Two sets of Focal Polykevlar components, and Alpine CDA-9855 Head Unit, Something like an ARC Audio 4150XKK 4 channel amp, 1500XKK Mono amp and a single Image Dynamics IDMax 12" (trust me, it'll be enough).
The other way is to put some decent comps in your doors, and get a set of coaxs to replace the sail panel speakers, and power all of them with a 4 channel amp. Then again add a dedicated sub amp for your 12s.
As far as brands go there is so much stuff out there that you really have to go to some audio shops and listen to different speakers and amps and decide for yourself what sounds the best to you.
I can throw a few names at you that alot of people seem to have had good luck with. Speakers: MB Quart, Focal, Diamond Audio, Alpine, Pioneer, Infinity, Polk. Amps: Rockford Fosgate, Alpine, Jl Audio, Kicker, Sound Stream, Kenwood. These are in no particular order.
I personally have Infinity Kappas in my doors and sails, a Jl Audio sub, Two Rockford amps, and a Kenwood H/U. Your brands don't have to match, the stuff just has to sound good to you. Good luck.
the whole idea behind superior sound quality is reproducing a live performance...where, everything comes from the front...
If you only have two speakers in your doors, then you would need a two channel amp for them, and a class d mono amp for your subs. You can also use a four channel amp hooking the front two channels to your doors, and bridging the back two channels to power your subs. (assuming your amp is bridgeable).
If you have four speakers you would use a four channel amp to power them, and a seperate mono amp for your subs, or you could get a five or six channel amp.
It all depends on how you want to set things up. You have to consider a few things, how many ohms your subs will be, how many ohms your amps are stable at, and how many speakers you will be running. You really can't get too specific of an answer until you you decide how you are going to do things.
EDIT: i didnt read all of the post before me, sorry for double posting the idea of the 4channel!
