Is there a wire that is hot only when engine runs
Old Apr 8, 2006 | 11:39 AM
redtail2426's Avatar
Default Is there a wire that is hot only when engine runs
I am wondering if there are any wires that would be hot only when the engine is running.I want to use one to hookup a wideband.thanks. I have to ask as i dont have my car here with me.
Old Apr 8, 2006 | 12:24 PM
Z28LS1camaroguy's Avatar
yeah that big bolt looking thing in the engine bay, or the ignition fuse in the fuse panel. only comes on when the engine is running or accessories is on.
Old Apr 8, 2006 | 01:43 PM
yeah i dont want it when accessories are on,only when engine is running.
Old Apr 8, 2006 | 02:09 PM
EDS01SS's Avatar
In that case no there isnt a wire like that. All the wires will be energized with the ignition on unless there is a seperate switch in the circuit.A seperate switch in the system would be my suggestion to you.
Old Apr 8, 2006 | 02:30 PM
yeah i think i might have to...
Old Apr 8, 2006 | 04:02 PM
JDM_99Z's Avatar
I hooked my auto meter gauges up to the guages fuse in the fuse panel.
Old Apr 9, 2006 | 10:49 AM
WhiteBird00's Avatar
Ungrounded Moderator
Do you want one that is hot only when the engine is running or only when the key is in the run position? There is no wire that is hot only when the engine is running but I believe there are a couple that are hot when the key is in the on position but not in the accessory position. In fact, the IGN accessory port in the dash fuse panel is a good example (although it may be hot in the start position as well).
Old Apr 9, 2006 | 11:00 AM
only when the engine is running,and i think there is one for the evap system and the stock narrowband sensors.According to the diagram it is only hot when the engine is running.I will find out next weekend when i get the car out.
Old Apr 9, 2006 | 01:35 PM
RUNINHOT's Avatar
The fuel pump wire goes on only when the engine is running. But it comes on and goes off when you put the key in the run position. It would require a relay to run any thing off of it though.
